Do you think there's something defective about your bridge or just inherent to the design?sunburster wrote: ↑Fri Aug 25, 2023 1:37 pmIt is the new 52mm one. Those became standard starting with the LPB run in 2018.
Johnny Marr Sig Jaguar
- GilmourD
Re: Johnny Marr Sig Jaguar
- sunburster
I don't think it's defective. It works as a bridge should, I just don't like the sound.
I've read a lot of people complain about these sounding dull, attributing it to the pickups (and, often, swapping them out). Try changing the bridge first!
- GilmourD
So odd... I would love to see/hear an A/B comparison between the Marrguar bridge and the Staytrem on the same guitar.sunburster wrote: ↑Fri Aug 25, 2023 1:45 pmI don't think it's defective. It works as a bridge should, I just don't like the sound.
- GreenKnee
Yeah that's odd because the Marr bridge was originally a Staytrem. Same design with the Mustang style saddles, nylon bushes to prevent bridge dropping etc.
Personally, I've found a Staytrem to sound more traditional and like the stock, threaded saddle bridges. Mellow, if you will, less bite and attack. A Mastery is much more like a Tele bridge - the attack and bite is all there, full frontal and for me personally is a lot more alive.
Surprising that reverting to a vintage bridge brought the guitar to life for you, but that's great news for you that you're enjoying the guitar much more since making the swap.
- GilmourD
I've often associated a softer sound like that to something not firmly connected or impeding vibration... Or a metal somewhere that's softer.GreenKnee wrote: ↑Fri Aug 25, 2023 2:30 pmYeah that's odd because the Marr bridge was originally a Staytrem. Same design with the Mustang style saddles, nylon bushes to prevent bridge dropping etc.
Went I put the Gen1 Staytrem on my Enterprise Jazzmaster it didn't seem to have a completely different tone but... More nuance, maybe? Like different emphasises at different frequencies but the same general ballpark.
- GreenKnee
Yes, definitely. In my experience, the Staytrem keeps all the good sounds from the vintage style bridge but just adds a bit of life and excitement. It's the closest you'll get to the stock sound whilst also having that reliability and stability that the Staytrem brings.
I am surprised that going from the Marr bridge to the original style brought the guitar to life, but I'm pleased it worked.
- GilmourD
Yeah... That's why I'm wondering what's up with the bridge now... I REALLY want to science this out... I have a 7.25" radius Jaguar neck but it's stuck on a mustang body that is nowhere close to being ready for electronics and whatnot and my only other Jaguar body is completely unfinished waiting for paint... Yet another reason I need to get that stupid cheap Jag body I have a wanted post for.GreenKnee wrote: ↑Fri Aug 25, 2023 2:41 pmYes, definitely. In my experience, the Staytrem keeps all the good sounds from the vintage style bridge but just adds a bit of life and excitement. It's the closest you'll get to the stock sound whilst also having that reliability and stability that the Staytrem brings.
- sunburster
The bridge that comes on these is not a Staytrem, it is just a Mustang bridge with nylon bushings on the posts. Staytrem saddles are made of different material, there are no intonation springs, and their intonation screws are off-center. I've tried a Staytrem before and although I still prefer the traditional bridge, it at least sounded better than a Mustang bridge.
Another problem the Marrstang bridge has is it doesn't rock back and forth. I found my tuning went out quickly if I used the tremolo a bit, due to this (due to the strings "sticking" as they move back and forth on the bridge saddles, I guess?). After putting in the traditional rocking bridge, it stays in tune much better with tremolo use.
- GilmourD
sunburster wrote: ↑Fri Aug 25, 2023 6:18 pmAnother problem the Marrstang bridge has is it doesn't rock back and forth.
- Meriphew
I've got a Mastery bridge on my KO Marr and the stock 52mm bridge one my LPB Marr. The LPB Marr plays sounds great - I found no reason to swap the bridge. My KO came with the 55mm bridge, which caused the low E to slip off the fretboard.
I almost think that Fender should have offered the new 52mm bridge as a free replacement to those who had guitars with the 55mm bridge.
- Bradley-Jazz
Yes - it seems baffling that a 55 was ever considered, never mind installed. I put a Staytrem on my KO. I don’t recall the original bridge sounding awful, but the strings coming off the edge of the board was enough of a problem so that it wasn’t on there for very long at all.
All the cheeses....
- GilmourD
This hasnt been addressed regarding the Marr bridge not rocking.GilmourD wrote: ↑Fri Aug 25, 2023 6:47 pmsunburster wrote: ↑Fri Aug 25, 2023 6:18 pmAnother problem the Marrstang bridge has is it doesn't rock back and forth.
- Futuron
Sleeves hold it in place. Like the American Professional.
- GilmourD
- Bradley-Jazz
On mine, the sleeves just stopped the height adjustment screws from dropping, like a Staytrem. They didn’t stop it rocking. The whole original Marr bridge was basically a less well executed Staytrem with the wrong string spacing, as far as I’m aware.
All the cheeses....
