So the search function is case sensitive...
- Stereordinary
As I found out the hard way. I don't suppose there's any way to change that is there?
- mcconnachiea
Re: So the search function is case sensitive...
Particularly annoying when what you're searching for is like 'OmG jAGuaAR bbrRIDJ iZ tEH kUrtDZZZZZZZZzzzZZZZ!!!!One!!!!1!!'
- Orang Goreng
Strange. I just did a search and the results had a different case than the term i used (lower case search yielded result with caps). Are you sure?
- Stereordinary
Well, ok... so here's what happened:
I did a search for "Top Five".
It returned with nothing.
I tried searching for just "Five".
Nothing.
So I searched "top five".
and I found the thread I wanted at the top of the list.
Then I went and started this thread.
Then I went back to search to pull up the thread I was looking for originally. I used the Windows search field pull down thingy and picked "top five" from the list. And the thread I was looking for was way down on the list.
I had the Search in Topic Subjects Only checkbox checked every time I searched.
Nothing.
