A case of the baskets...
- fever606
To be quite honest, I'm not really even sure where to start...
- Axolotl
- Horsefeather
Re: A case of the baskets...
Flame maple cap time!
- fever606
I laugh because it hides the tears…
Yeah… I believe it to be 60s (which is why I out it here instead of Mods & Projects) so hopefully I can get a plan together to get this back in fighting shape…Is it a Jag?
Yes to whatever the opposite of that is!
- will
That's bizarre!
Did it come to you as just the body?
Was there enough wood there to have enough depth for the trem to work?
You could take it to a woodworking place that does thickness sanding and have them sand it down so that you have a flat surface to glue a 1/4 or 3/8 slab of alder onto (or more? not sure how deep the damage goes!)
- parry
- fever606
Yeah, just the body...will wrote: ↑Mon Jul 26, 2021 9:22 amThat's bizarre!
There's only about an inch of depth left in the vibrato cavity... I test fit a Squier unit and it doesn't seem to rub anywhere, but not sure how that would go in practice.
And thanks for the sanity check... my gut was saying basically to sand or plane it down level behind the bridge and across to the rhythm circuit cavity and then laminate fresh wood on that I could then shape correctly. Looks to only need about 1/4" (putting a straight edge across the pickup cavities and bridge posts and measuring down) so... not great but not awful.
Best as I can figure it was originally sunburst... the white is over the blue, which is over the red, which is over the "orange"...
- peterherman
Did they route that middle pickup with a SPOON?!
- will
Curious to see what becomes of this body. It would have been a good match to the heavy metal Jaguar neck I fixed up a while back!
- fever606
Well it’s been a year and I haven’t made any progress on the body, but I did get this ‘65 dot-and-bound neck to join the party…
- will
- fever606
Oh… I have that thread bookmarked!will wrote: ↑Fri Oct 07, 2022 7:12 amThat neck reminded me of this old project!
viewtopic.php?f=42&t=113456
- Chippertheripper
You’re ready to join APlaceToBuryStrangers.
- gishuk
Whoever owned this in the past must have been on something
