Jazzo-Sonic | Restoring a '62 Jazzmaster
- PJazzmaster
Re: Jazzo-Sonic | Restoring a '62 Jazzmaster
Subscribed
- terminalvertigo
Highnumbers wrote: ↑Thu Jun 16, 2022 5:05 amI’m going to leave that endeavor up to somebody else.terminalvertigo wrote: ↑Thu Jun 16, 2022 4:40 amthe real treat will be watching the duo sonic come back to life
Personally I think there is nothing left to restore!
- Highnumbers
Lol.terminalvertigo wrote: ↑Thu Jun 16, 2022 11:52 am[/img]Highnumbers wrote: ↑Thu Jun 16, 2022 5:05 amI’m going to leave that endeavor up to somebody else.terminalvertigo wrote: ↑Thu Jun 16, 2022 4:40 amthe real treat will be watching the duo sonic come back to life
Well... I've seen people attempt some crazy shit in the past, you never really know.
- Highnumbers
Thread update!
After the 1/4" veneer was applied with epoxy, the next step was cutting the excess off, I didn't want to sand the edges much (or at all) to retain the original body dimensions/shape. I also cut off the foream contour excess because it was just sticking out
Some basic filing of the edges for the contour. I ended up shaping the contour back to factory specs with a handheld belt sander (carefully!) followed by a sanding block. I have to say, it's totally satisfying when this contour came back to it's full original shape. You can't feel it at all running a hand across the joint.
As luck would have it, one of my other Jazzmasters is a totally original '62, which made for the perfect reference point for all sorts of specs on the body, from the shape to the route depths to the contour shapes.
I started working on opening up the original factory cavity routes. Aside from the lower control routing, all of the other cavities were intact (both pickups, trem and rhythm circuit). I drilled with a forstner bit to open up the route area, then used a flush-cut bearing bit to follow the original cavity edges for a perfect shape. In the course of doing so, I found that the available aftermarket templates are *slightly* off a 1/16th of an inch here or there. Nothing you would really notice if you weren't trying to use them on an original cavity.
Here I have leveled the body half, preparing to mate it to a piece of fresh alder for the treble side, both planed to the matching correct thickness.
I attached the other side of the body with epoxy - again because I don't want this coming apart in the future.
Continuing to open the factory routes on the bass side of the body, while also routing the control cavity on the new half (before cutting the body to size). Shout-out to Javelina Guitars (who sell templates on Reverb), really high quality stuff that helped with this project quite a bit.
Lastly, it was just a matter of using the template and tracing from my original '62 JM to get the body outline started. Then cut it out to shape on a bandsaw and final shaping with a spindle sander and disc sander.
Starting to look like a Jazzmaster again! The next stop is doing the edge roundover on the body with a 7/16" router bit, and then doing all the fine sanding to prep it for sealer and paint. That'll have to wait a week or two, though.
Finally (and this is subject to change), I have decided on Sherwood Green w/matching headstock for the final color selection. One of my favorite custom colors and one that you don't see very often on 60s Fenders.
- caples
It’s looking really good! Actually starting to look like a jazzmaster again.
1969 Comp Blue Mustang, 1965 Natural Jaguar
- sal paradise
Thought there would be more love for this… amazing work so far
- DaddyDom
Every time I try to type my undying love for this thread, the drool swamps my keyboard.Thought there would be more love for this… amazing work so far
- maximee
Awesome restoration, can’t wait to see more progress. Sherwood green is also
- Jazzmastervsjaguar
Amazing! Can’t wait to see how it ends up!
- Highnumbers
Thanks everyone! I appreciate the kind words.
It’s been a fun project so far and I’m looking forward to getting the final prep done on the body and color back on it
I’ll have more pics later this week.
- maximee
Is it already later this week?
- Highnumbers
Ha! I’m working on the guitar today (finally, it’s been a busy week). Hopefully more photos soon, I’m working on the contour edges.
- maximee
Looking forward to seeing that. Thinking about re-contouring a Korina JM of mine, so that’ll be cool to see!
- caples
Looking forward to seeing how it turns out :-)
- T70
Wow, this is quite the project, and a testament to your woodworking skills. I draw the line at chopping 2x4s! Nice work.
