Brazilian rosewood on jag 63 - is this one real or changed?
- Guitarman555
Hi, this is a rosewood from a cool jag - 63 with many repairs and new electronics. I was told neck was refretted with PLEK technology recently. I beleive this is repaired Brazilian rosewood, right? Looks to me a bit different than Brazilian that I have seen so far from this era, it has less pores and is slightly less dark. It has also a repair at the edge. What do you think, is it original Brazilian wood?
rosewood1
rosewood2
rosewood3
rosewood1
rosewood2
rosewood3
Re: Brazilian rosewood on jag 63 - is this one real or changed?
You'll never definitively identify Brazilian rosewood. It has a huge amount of natural variation that overlaps with every other rosewood species.
Short of lab analysis, not much you can do to be sure.
- AwesomeWelles
It sure looks different than the one on my '64 JM. Also looks quite new/unworn.
But that's like...my opinion.
- Liquitone
The edge of the rosewood in picture 1 looks oddly sharp. I would expect it to be rounded off a bit, even without wear.
- Guitarman555
Maybe the rosewood was sanded?
- GreenKnee
Yeah the board may well have been levelled for the refret (those are 100% new frets).
I had my '62 refretted and the board needing levelling for it, here are the before and after shots. Looks similar to this '63 in OP. My board has since darkened back down after about a year of regular playing.
- Guitarman555
yeah, your second picture after levelling fretboard is very similar to my jag fretboard. As you said it was refretted (btw PLEK method was used).
- GreenKnee
Yeah I wouldn't worry about your fretboard at all, looks good. I imagine the pores of the wood open up somewhat over 60 years of being on a neck and so when the board is levelled it's starting from scratch again.Guitarman555 wrote: ↑Wed Aug 10, 2022 4:03 amyeah, your second picture after levelling fretboard is very similar to my jag fretboard. As you said it was refretted (btw PLEK method was used).
Enjoy it
This was my thought too. Usually tbe board gets sanded during a refret. I wouldn’t expect the difference in thickness to be dramatic as the veneer isn’t very thick to begin with.GreenKnee wrote: ↑Wed Aug 10, 2022 3:54 amYeah the board may well have been levelled for the refret (those are 100% new frets).
Replacing a veneer board would be possible I suppose, but kind of a pain, and there would be discrepancies in the finish if so.
- Highnumbers
Definitely, Brazilian is all over the place. There is natural variation and also differences based on the climate where the guitar has resided, or maintenance (how many times it's been oiled, polished or even sanded).
Ironically, this is supposed to be the hardwood that Customs officials identify under CITES? Good luck identifying it visually.
It's a safe assumption that a 1963 Fender has a BRW board, just based on their lumber supply at the time.
- Highnumbers
Better photos would help identify things.Guitarman555 wrote: ↑Tue Aug 09, 2022 1:38 amHi, this is a rosewood from a cool jag - 63 with many repairs and new electronics. I was told neck was refretted with PLEK technology recently. I beleive this is repaired Brazilian rosewood, right? Looks to me a bit different than Brazilian that I have seen so far from this era, it has less pores and is slightly less dark. It has also a repair at the edge. What do you think, is it original Brazilian wood?
rosewood1
rosewood2
rosewood3
In particular the second photo, of the repair. The neck/repair area is entirely out of focus.
- bluemonday
Based on the pictures, I do think it's Brazilian rosewood! Let's put it this way, there is nothing in the color and grain that would cause me to question it. Some variegated streaking in color are not at all uncommon. Just as importantly to me is the tell-tale pores in the wood which run along the grain. Comparing your fretboard with GreenKnee's second photo above, I find this to be identical in character.Guitarman555 wrote: ↑Tue Aug 09, 2022 1:38 amHi, this is a rosewood from a cool jag - 63 with many repairs and new electronics. I was told neck was refretted with PLEK technology recently. I beleive this is repaired Brazilian rosewood, right? Looks to me a bit different than Brazilian that I have seen so far from this era, it has less pores and is slightly less dark. It has also a repair at the edge. What do you think, is it original Brazilian wood?
rosewood1
rosewood2
rosewood3
- Mechanical Birds
Wow that’s wild! If I were to see that Without knowing in person I’d swear it was newer. I love how it looked pre-regret though, I’m a sucker for the way the old stuff seems to wear
- GreenKnee
I loved the look of the board as well but some imbecile had it refretted with the world's biggest frets and did an awful job on it, superglue all over the place. It's now a much superior guitar and plays an absolute dream so it was 100% worth it.Mechanical Birds wrote: ↑Thu Aug 11, 2022 9:30 pmWow that’s wild! If I were to see that Without knowing in person I’d swear it was newer. I love how it looked pre-regret though, I’m a sucker for the way the old stuff seems to wear
- 46346
Wow - that's my birthday neck! i know the 1 is for Jag, and not a date, but...
