The LCD basses had generic Gibson EB/SG type bridge pickups fitted to them - they seem to be a direct replacement size-wise. The 280 has curious pickups - the pole pieces are sort of 'loose' and sit on a bar inside held by magnetic force. I can't explain as not technical but if you shake the bass really hard you might hear that the sound changes as the pole pieces have moved along the bar.
The ARIA 1802t/1803t - EPIPHONE ET 270 DATABASE
- sumlin
Re: The ARIA 1802t/1803t - EPIPHONE ET 270 DATABASE
- rank
Anyone have a picture of this bass?
We are merely moving shadows.
- TheGroke
Has anyone on this list ever figured out a good drop in tuner replacement for the 1802T? As has been pointed out, there is way too much wiggle room before the gear is even engaged (particularly in the tune down direction) on the stock ones. Makes this guitar very tough to use live. But I love it otherwise.
Two options seem to have been presented:
viewtopic.php?f=41&t=60667&p=1587241&hi ... s#p1587241
viewtopic.php?f=41&t=60667&p=1602728&hi ... s#p1602728
Did either require drilling?
What is the model number for the Schallers (assuming they are no-drill)?
Thanks! DT
Thanks! DT
- CROSS_guitars
The Schaller tuners I installed on mine did require re-drilling. The holes almost lined up but I still had to plug them and re-drill.
Totally worth it though. They are amazing quality.
- Fiddy
Those tuners look great. Were there going to be any holes exposed?CROSS_guitars wrote: ↑Fri Jun 25, 2021 7:28 pmThe Schaller tuners I installed on mine did require re-drilling. The holes almost lined up but I still had to plug them and re-drill.
- CROSS_guitars
I'm not entirely sure what you mean? The schaller tuners cover the existing plugged holes.tribi9 wrote: ↑Fri Jun 25, 2021 7:51 pmThose tuners look great. Were there going to be any holes exposed?CROSS_guitars wrote: ↑Fri Jun 25, 2021 7:28 pmThe Schaller tuners I installed on mine did require re-drilling. The holes almost lined up but I still had to plug them and re-drill.
- TheGroke
Got a pair of replacement 1802t tuners off an ebay seller. Looked exactly the same as what came on my 1802t, but it turned out that the hole spacing is just a 1/2 mm or so off from my original ones. So, I still can't put them on without drilling, and now I must fill first before doing so. ARGH!
So, lesson learned (and not reported before in this thread) is that there seem to be some variants of these tuners.
The original ones bend very easily in places, which is half of the reason why they stop working right. The other reason being that the pole separates in one spot.
The metal is also slightly thicker in places on the new ones and does not seem to bend as easily. So, perhaps this change was made on purpose on later models.
- Ogrewatch
Hello everyone, I hope this is an acceptable thread to ask this in. I recently got an Epiphone ET275, which I believe has the same bridge and trem as the 270.
It's missing the bridge action adjustment screws, and I'm having trouble finding out what size they are. I took the bridge to a hardware shop and an M3 would start threading in, but not go all the way. And an M2.5 was definitely too small.
Does anyone happen to know the correct screw size, or even have some I could purchase?
I'm thinking it might be a fine thread M3, or I may have to chase the threads with a tap. But I'd rather not just in case I'm wrong on the size.
http://imgur.com/a/8gn7glZ
- Mechanical Birds
Man would I love to get my hands on one of these. I had an 1802T for like a minute but traded it for something before ever really getting to spend much time with it.
Like a lot of my guitar realm situations, I regret not buying one when they were ~$200 or whatever because psychopaths are listing them now for ~$1,000 and thus out of my comfort zone on price/quality.
There are a bunch of Guyatone guitars I want too but the same thing is happening with them, unfortunately.
- pikmin
I just got this beautiful refinished Aria 1802t in a trade and I love it !
It’s beautiful , it’s joy to play and I love how it sounds ...
55130178-1252-47A5-A6CC-9852CB35BBD7 by Eric Delsine, sur Flickr
- adamrobertt
Wow! Love what's going on with the headstock!pikmin wrote: ↑Sat Sep 11, 2021 3:11 pmI just got this beautiful refinished Aria 1802t in a trade and I love it !
Unrelated: is there a source for replacement pickups for these things? I just bought a fixer-upper 1802t and the seller says the bridge pickup is dead - not sure what the issue is yet but I'm just putting out feelers.
- s_mcsleazy
any excuse for me to post this picture of justin trosper from unwound's ET270's pickup coming unwoundadamrobertt wrote: ↑Sun Sep 19, 2021 4:52 pmWow! Love what's going on with the headstock!pikmin wrote: ↑Sat Sep 11, 2021 3:11 pmI just got this beautiful refinished Aria 1802t in a trade and I love it !
- Sweetfinger
The only place to find replacement pickups for these is... these. Maybe get lucky and find one on eBay from a parted out junker. My advice is to either take the pickup to someone who can rebuild it with a new coil, or send it to be rewound or repaired.
- UC3
Just for grins...
The original image was lost in the Photobucket "transition".
Looks like Trosper's was the version on the right.
Regards,
Mark
Regards,
Mark
- adamrobertt
Are the bridges on these non-adjustable?
