Vintage Mustang Database (1964 - 1980)
- FenderBob
Re: Vintage Mustang Database (1964 - 1980)
Have a bunch I could add when I get some time.
- Pacafeliz
Git ready OSG!
- FenderBob
- FenderBob
Just looked - have like 230 serial numbers of mostly comp stangs. I went really hard for several years. But they are folders. not in MS WORD or EXCEL format. Would take some time to convert into a clean list.
- superficial
Someone can probably help write a very simple terminal / shell command to list folder names.
For example, on a Mac (Or 'nix) terminal you'd navigate to the folder where the subfolders are listed, and type:
Or, if you folder structure is messy but you can search for a certain string or some other identifier, you'd type:
Code: Select all
ls -d */
Code: Select all
find . -type d -name "Mustang"
- FenderBob
Thanks for the suggestions. Don't have a MAC, have a PC. Would it be just as easy?superficial wrote: βSun Apr 16, 2023 2:29 pmSomeone can probably help write a very simple terminal / shell command to list folder names.
Or, if you folder structure is messy but you can search for a certain string or some other identifier, you'd type:Code: Select all
ls -d */
Code: Select all
- caples
Wow 230 is crazy if you could make it into a list
1969 Comp Blue Mustang, 1965 Natural Jaguar
- luau
- Admin
Sure, just open a command prompt with the 'cmd' command and then change to the drive and directory containing all the goodies and redirect a directory listing to a file. Say your root folder containing everything is on drive X and in folder 'goodies'.FenderBob wrote: βSun Apr 16, 2023 3:58 pmThanks for the suggestions. Don't have a MAC, have a PC. Would it be just as easy?superficial wrote: βSun Apr 16, 2023 2:29 pmSomeone can probably help write a very simple terminal / shell command to list folder names.
ls -d */
Code: Select all
At the command prompt:
Code: Select all
x: <enter>
cd \goodies <enter>
dir /s /b > listing.txt <enter>
edit: This will only work if the information you wish to extract is contained in directory and file names. If you have the information inside of a text file or something then that'll take a more comprehensive set of commands but is still doable.
- sam
- Pacafeliz
Oh damn
- Pacafeliz
- sal paradise
Oh my gosh thatβs gorgeous
- 68 Blackline
1976 Mustang, natural as the previous post. It's near the end of the white guard SN on the neckplate style. F7087XX
- caples
Sorry for the delay everyone, should be updated as of now
- ldp54002
Mine is a 1965 in Dakota red.
L33409 - B neck with date stamp OCT65
The left is a refin'd parts 'stang, the right is a 2008 CIJ MG-73.
