E-Bass Signal is too quiet. boost it?
pad
Post by pad » Mon Mar 29, 2021 9:16 am
Hi folks,
I recently acquired a Fender Bassman 10 and a Kremona Violin Bass.
That setup sounds awesome, but it is really low volume with that Bass.
viewtopic.php?f=9&t=118799 <-- NBD
The Pickups are rated between 3,4k and 4,2k, that is a hint there.
Compared to my Rickenbacker 360 with hi gains it is like 20-30% of the Volume.
From Rehearsal to Bed-Room Volume, kinda.
Two ways out of it:
1) Adding any clean-boosting Pedal
2) Changing PU´s or get them rewinded.
Any other options?
Im not sure what would be the best way to do it.
Sound-wise it is dead-perfect to what i imagined how it should sound,
im really happy with the whole thing!
I got a Two-Notes Captor to silence record the whole quiet at home.
NBD, NBAD, NPD will follow :ph34r:
pad
Re: E-Bass Signal is too quiet. boost it?
Post by pad » Tue Mar 30, 2021 12:26 am
no ideas?
Zork
Post by Zork » Tue Mar 30, 2021 7:44 am
Have you checked and measured the wiring and the pots? Is it all working properly or are there any weird resistors or caps soldered in?
pad
Post by pad » Tue Mar 30, 2021 12:12 pm
ive redone the full wiring, its now 3x 250k cts pots with 1 orangedrop cap. :/
Wired as a J-Bass configuration.
pad
Post by pad » Fri Apr 02, 2021 5:10 am
no ideas? i think the wiring works! or would pics help?
one more thought about pickups, what would happen if i put cheap goldfoil- guitar pickups in there?
that could be a cool combination, right?
otherwise id go for höfner-style copy ones. rated around 10k id think
Id like to stay on the cheaper side of life. :w00t:
https://de.aliexpress.com/item/10050022 ... hweb201603_
no affil, but those are in the exact same measurement then the original ones. rated to 6k
pad
Post by pad » Fri Apr 02, 2021 8:47 am
oops wrong topic
