cheapest possible sampler/sequencer that is NOT a volca?
- bah humbuck
So I impulsively downloaded 12 GB worth of drum machine samples from Reverb for $7 and am now facing the fact that I need a new piece of hardware if I want to do anything with them. Everyone I know seems to use a Volca Sample but it sounds like you need an iPhone app to actually load the samples into the machine and I don't have an iPhone. Even if I did, getting 12 GB of wavs into my phone sounds like a nightmare. Ideally, I'd like something that takes an SD card or that can connect via USB to my Thinkpad. Beyond that, my only requirement is that I can switch between a few different patterns easily. I don't need any built in effects as I will be running the thing through pedals anyway. I don't care who made it or when as long as the interface is somewhat intuitive -- I have a working understanding of how to operate a sequencer thanks to my experimentation with acidmachine. Ideally my budget is $150 or less (I don't know how realistic that is). Any suggestions?
- mim blacktop jazzmaster (modded w/ tune-O-matic)
- eko camaro
- aria pro ii fullerton
- sx furrian hh
- behringer vd400
- boss dd-6
- arena reverb
- peavey special 130
- eko camaro
- sx furrian hh
- behringer vd400
- boss dd-6
- arena reverb
- mackerelmint
Re: cheapest possible sampler/sequencer that is NOT a volca?
My suggestion is to get the Volca sampler and use it with free third party software you run on your computer.
https://www.korg.com/us/products/dj/vol ... tyapps.php
good excuse for an mpc500
- gusgorman
You could get any old MIDI drum machine and then sync it up to a software sampler on your laptop using a USB MIDI interface.bah humbuck wrote: ↑Thu Nov 05, 2020 12:46 pmSo I impulsively downloaded 12 GB worth of drum machine samples from Reverb for $7 and am now facing the fact that I need a new piece of hardware if I want to do anything with them. Everyone I know seems to use a Volca Sample but it sounds like you need an iPhone app to actually load the samples into the machine and I don't have an iPhone. Even if I did, getting 12 GB of wavs into my phone sounds like a nightmare. Ideally, I'd like something that takes an SD card or that can connect via USB to my Thinkpad. Beyond that, my only requirement is that I can switch between a few different patterns easily. I don't need any built in effects as I will be running the thing through pedals anyway. I don't care who made it or when as long as the interface is somewhat intuitive -- I have a working understanding of how to operate a sequencer thanks to my experimentation with acidmachine. Ideally my budget is $150 or less (I don't know how realistic that is). Any suggestions?
Something like an Alesis SR-16, an Alesis HR-16?, or a BOSS DR-660?
Thats just the first few examples that pop to mind but I'm sure there are other options. Basically any drum machine that sends out MIDI will give you what you want.
With regards to software samplers - I don't actually know of any because I'm a bit out of touch
edit: Actually the BOSS RD-660 sequencer wasn't as nice to use as alot of other drum machines around at the time so maybe tread carefully with that one unless you get to try it first. Some people did like it.
- stevejamsecono
It's so hard to understand
Resident Yamaha Fanboy
- MKR
teenage electronics pocket operator KO. pretty sure this is the cheapest sampler/sequencer around. I have one. They're SUPER FUN!
- MKR
EDIT: just read the first post, and that's not a good option for what you're after, but I still maintain that they are super fun little music machines.
- Nick and the Noise
Indeed. Just get the Volca Sample V2.stevejamsecono wrote: ↑Fri Dec 04, 2020 3:26 pmI'm pretty sure the new Volca Sample has USB-In?
https://www.korg.com/us/products/dj/volca_sample2/
