Studio “recording” light setup?
- hillerheilman
Hey forum, I have a somewhat odd question.
I’m thinking about getting a light for outside the room where I record all my music to indicate to my roommates that I am in fact recording. I use an audio interface and an iPad for pretty much everything, and I’m wondering if there’s a way that I could somehow sync the light to turn on and off with the recording button in my iPad daw.
Does anyone know how I could do something like that?
- Dok
Re: Studio “recording” light setup?
Not sure if this will work since you're on an iPad and not a computer, but...
https://www.punchlight.com/recording_lamp_usb
Local milk person
A little clunky, but you could use an audio controlled relay (RDL ST-ACR1) connected to a spare analog output on your interface and use that for contact closure to trigger something like a Lowell RPC-15-S that your “recording” light is plugged into.
So, your backing track/ click starts up, the audio controlled relay senses it and triggers the power control device to apply power to whatever is plugged into the receptacle. Once the relay stops sensing audio contact closure is released to the power control, and the sign goes off.
That Punchlight looks way simpler though.
Can't you just get an "On Air" sign of some kind?
Does it really need to be sync'ed to the record button, or can't you just hit it when you know you will be recording and leave it on for the duration?
- hillerheilman
Fair point, Larry.Larry Mal wrote: ↑Tue Aug 18, 2020 2:21 pmCan't you just get an "On Air" sign of some kind?
I just wondered if it could be done for convenience/coolness.
Have I mentioned that I sometimes over complicate things needlessly?
We all do. There wouldn't be a forum without it.hillerheilman wrote: ↑Tue Aug 18, 2020 2:25 pm
Have I mentioned that I sometimes over complicate things needlessly?![]()
- jorri
Smart WiFi lightswitch, I'm sure tons of things like that. One i've seen is just controlled to a phone app.hillerheilman wrote: ↑Tue Aug 18, 2020 2:25 pmFair point, Larry.Larry Mal wrote: ↑Tue Aug 18, 2020 2:21 pmCan't you just get an "On Air" sign of some kind?
But with the record button? I do not know- i bet someone could come up with a Reaper command, they usually do. (but you're not using that!)
How are you at writing code?
- hillerheilman
Not a code literate guy myself, but the WiFi based switch could be a solution...jorri wrote: ↑Tue Aug 18, 2020 4:53 pmSmart WiFi lightswitch, I'm sure tons of things like that. One i've seen is just controlled to a phone app.hillerheilman wrote: ↑Tue Aug 18, 2020 2:25 pmFair point, Larry.Larry Mal wrote: ↑Tue Aug 18, 2020 2:21 pmCan't you just get an "On Air" sign of some kind?
- øøøøøøø
I've never tried anything like this, but you could probably set something up via MIDI.
If you had, say, a set of MIDI transport controls, you could probably set that up so it fires off an extra set of MIDI messages when you hit "record" or "stop." Then it's just a matter of figuring out how to get this MIDI message to control the light.
A bit outside my wheelhouse, but I'm sure it's possible.
- MazzyJaster
Can't you leave a note on the door saying Do Not Disturb?
- hillerheilman
Yeah, I could. As I said above, I over complicate things sometimes. I just wanted to see if it could be done for the coolness factor and convenience.MazzyJaster wrote: ↑Tue Sep 01, 2020 5:22 pmCan't you leave a note on the door saying Do Not Disturb?
- MazzyJaster
Sorry, it was just a jokehillerheilman wrote: ↑Wed Sep 02, 2020 2:31 amYeah, I could. As I said above, I over complicate things sometimes. I just wanted to see if it could be done for the coolness factor and convenience.MazzyJaster wrote: ↑Tue Sep 01, 2020 5:22 pmCan't you leave a note on the door saying Do Not Disturb?
- øøøøøøø
A quick google reveals that someone has already figured the MIDI angle out.øøøøøøø wrote: ↑Wed Aug 19, 2020 7:12 pmI've never tried anything like this, but you could probably set something up via MIDI.
Bob's yr uncle:
https://www.punchlight.com/recording_strip_usb
- Dok
A quick read of THIS THREAD would reveal that tooøøøøøøø wrote: ↑Thu Sep 03, 2020 4:40 am
Bob's yr uncle:
Seriously, though, I wish I could get one of these for every room in my house so NOBODY MOVES when I'm recording...Dok wrote: ↑Tue Aug 18, 2020 1:45 pmNot sure if this will work since you're on an iPad and not a computer, but...
Local milk person
- fever606
Assuming the REC button on your DAW sends a MIDI CC when pressed (it probably does), you could get a MIDI-capable DMX controller (or put together something like this) and go from there...
https://youtu.be/TlQPGW-gHGE?t=110
