Re: Tabs
Sauerkraut
Tabs
Post by Sauerkraut » Mon Oct 02, 2006 7:50 am
How about a thread for posting and/or requesting tabs?
Re: Tabs
Post by zhivago » Mon Oct 02, 2006 8:22 am
cool idea...mind you, I usualy figure out things by ear....I find the scale and then most of the time the songs unlock themselves :)
Sauerkraut
Re: Tabs
Post by Sauerkraut » Mon Oct 02, 2006 8:47 am
zhivago wrote: cool idea...mind you, I usualy figure out things by ear....I find the scale and then most of the time the songs unlock themselves :)
me too, and sometimes I write it down.
I made a tab for Sonic Youth's Incinerate a few months back:
instructions:
It can't be played with a standard set of strings as they'd break, I used 0.46 0.46 0.36 0.26 0.26 0.18 because that was what I had lying around, I think a better set would be: 0.48 0.48 0.36 0.26 0.18 0.18.
Unfortunately I put a standard set of strings on the guitar again so I can't see how accurate the tab is.
These notes might sometimes seem vague but they were written by me for me  and I can use them perfectly, sometimes I leave some room for improvisation when I'm playing, which is why not everything is written down. This was never meant to be an accurate tab. Things I put between brackets are not always played or I don't always want to play them. There are 2 guitars used in the song and I'm not always following one, this is more of a selection of parts I want to play when I hear the song and they could be by either guitarist, in this case Lee or Thurston.
I sliced it all up into little parts hoping that'll make it easier to read, so anyway:
Part 1:
G -----0--0--0------0--0--0-----------------------------|
D#----0--0--0------0--0--0--------0----0--------------|
A#----0--0--0------0--0--0------0----0---0-----------|
D#----0--0--0------0--0--0---0------------------------|
D -----X--X--X-----X--X--X------------------------------|
                                            ^Randomly pick notes
                                                  in open chord
Part 2:
G --12--10--12--15--15--12--|--5--7--7--8--8--7--7--|
D#-------------------------------|--------------------------| whole part x2
A#-------------------------------|--------------------------|
D  -------------------------------|--------------------------|
                    (x2)
Part 3:
G  ----------------------|
G ----5---7---8---7----|
D#--(5)-(7)-(9)-(7)---| repeated a few times
A#---5---7---9---7----|
D#----------------------|
D  ----------------------|
Strum or pick around a bit with plectrum, or both.
hitting the open strings allowed as long as you mute the D.
Part 4:
G  ------------------------------------------------------------------|
G  -----------------5--7--(7)--5---3-(3)-(3)-5-------------------|
D#---4-----4--7------------------------------------2--4--2-------|
A#-------------------------------------------------------------2---| Whole part x 3
D#------------------------------------------------------------------|
D  ------------------------------------------------------------------|
                                                ^(picked fast)
it's a shame I can't check this part again, I remember I played it
differently (same notes, different positions) as I played it more often
end 3d time:
G  ----------------
G -5--------------
D#----2----------
A#--------2------
D#----------------
D  ----------------
(instead of
D# 2--4--2---
A# -----------2)
Part 5:
G ---------------------------------------------------------------------------------|
G ------5----7----------------5------5--5-----------7--8-7-8-7-8-7-----------|
D#-----5----7----------------5----5----5-------5--7-----------------9-7------|
A#-----5----7----------------5--5------5--5--5----7---------------------------|
D#--------------------------------------------------------------------------------|
D ---------------------------------------------------------------------------------|
                ^Basic chords              ^strum, pick notes and mess around
                                                  a bit with them like this, just try yourself
(1:32, Part 2, part 3, part 4, part 5 till 2:52)
Solo at 2:28 (during part 5): (use shitloads of distortion)
G ---------------------------------------------------------------------------------------------------------------------|
G ----5--5--7-8--10--12--12^13^12--10--8^10--8^10---5---5---5--7-8-7--5^7--5^7--5--3^5--3^5--|
D#---5----------------------------------------------------------------------------------------------------------------|
A#---5----------------------------------------------------------------------------------------------------------------|
D#--------------------------------------------------------------------------------------------------------------------|
D ---------------------------------------------------------------------------------------------------------------------|
2:41:
G ---------------------------------------------------|
G ----5------------5--------------------------------|
D#---5------------5---------7--5--4--2--0-------|
A#---5---7b9b7--5---7^9------------------0----|
D#--------------------------------------------------|
D ---------------------------------------------------|
      ^b as in bend and '^' (in tab) as in hammer on
2:52
then:
G --0---0-0-0---8--12--13--15--13--12-----8--12--13--15--13--12-----|
D#-0---0-0-0-----------------------------------------------------------(12)--|
A#-0---0-0-0--(9)(12)(14)(16)(14)(12)---(9)(12)(14)(16)(14)---------|
D#-0---0-0-0------------------------------------------------------------------|
D --x---x-x-x------------------------------------------------------------------|
at 3:05 the really cool bit start, it's actually quite easy to play:
G --0--3-5--0--3-5-5--0--3-5--0--3-5-5----0--5-7--0--5-7-7--0--5-7--0--5-7-7---|
D#------------------------------------------------------------------------------------------|
A#------------------------------------------------------------------------------------------|
D --------------------------------------------------------------------------------------------|
G-8-----10-----0--12-15--0--12-15--0--12-15--0--12-15-15--0--15-17--0--15-17--0--15-17--0--15-17-17-|
D#------------------------------------------------------------------------------------------------------------------------|
A#------------------------------------------------------------------------------------------------------------------------|
D -------------------------------------------------------------------------------------------------------------------------|
        ^strum both a number of times
G --20----22-------| 'make' the 22nd fret by pressing really hard with fingers on strings behind 21st (for JM-players)
D#------------------|
A#------------------|
D -------------------|
    ^again: strum both a number of times
(I'm not going to find out how many)
3:30
Part 1, part 2 (with 17th fret used as you please), part 3 (small stone phase shifter used from here), part 4 till end
4:55
Angel221
Re: Tabs
Post by Angel221 » Thu Oct 05, 2006 10:21 pm
Here is the link for most of the Sonic Youth tabs. Enioy
http://www.sonicyouth.com/mustang/tab/
Life on a Cool Curve
Sauerkraut
Re: Tabs
Post by Sauerkraut » Fri Oct 06, 2006 12:02 am
Angel221 wrote: Here is the link for most of the Sonic Youth tabs. Enioy
well **** me, I'm quite familiar with those pages but I just never clicked 'guitar' or 'bass'. I didn't even have to make that tab.
