I might change the Empress Tape Delay against a DOD Rubberneck. I had one of those before and it was a bit too dark and grungy for my taste back then, but I think in the current band/sound/setup it could fit very very well.
Killer set up as always. I fell back in love with my Analogman Chorus over the past few weeks after a few months using my Retrosonic Flanger instead. It's such a good sound.
Thanks Steve! Yeah I'd never really messed with chorus much till a friend gave me one of those cheapie $30 donner chorus pedals a while back, and man, the analog man is a whole different animal, so musical, works great with distortion/fuzz too!stevejamsecono wrote: ↑Wed Dec 23, 2020 9:56 amKiller set up as always. I fell back in love with my Analogman Chorus over the past few weeks after a few months using my Retrosonic Flanger instead. It's such a good sound.
It's very warm sounding and shockingly not noisy considering it's EHX circuit heritage. Sometimes I wish it was a bit more mids/highs focused like the CS-9 but then again I also rarely play totally clean so if I did I doubt I'd have any issues.
I used to have a modular system, and still do somewhat, where I had a delay and modulation board, a 2 dirt boards that I could switch out. One was more fuzz oriented and the other was overdrive/boost. Then I had a rack with a few digital effects like an SPX-900, or a Roland tape echo. There was an A/B switch that could send different signals to the 2 different amps. One Fender and one Vox.Shadoweclipse13 wrote: ↑Tue Dec 29, 2020 2:50 amAnyone ever split a big board into 2 smaller boards?
I love my big board and all the combinations I can make, but I wonder how I would love it if I put my splitter first, with one side going to its own board and amp. Just to experiment. My thinking is running it like parallel effects, but with no signal mixing back together, to try different flavors of drive simultaneously.
The rough idea I've got right now is this: [guitar] > tuner > splitter > [A: Catalinbread Naga Viper > EQD Dunes > EQD Hummingbird > Catalinbread Echorec > EQD Afterneath > [Fender '65 PRRI]] / [B: Fuzz > RAT (Magnetic Effects Lonely Robot) > Caroline Parabola > Caroline Kilobyte > Caroline Meteore > [Marshall Origin 20C]]
Just curious if anyone has tried it, and if they liked it/preferred it.
I was messing around with something along these lines earlier this year. Only using my splitter to have an effects channel and clean channel with light drive swapped polarity into my Deluxe Reverb. I may try something like this again but I just really like channel 2.Shadoweclipse13 wrote: ↑Tue Dec 29, 2020 2:50 amAnyone ever split a big board into 2 smaller boards?
That sounds insanely awesome. I love the modularity of it!!! Synth-fuzz and bit-crushing would be awesome to add to that.fuzzjunkie wrote: ↑Thu Dec 31, 2020 12:11 pmI used to have a modular system, and still do somewhat, where I had a delay and modulation board, a 2 dirt boards that I could switch out. One was more fuzz oriented and the other was overdrive/boost. Then I had a rack with a few digital effects like an SPX-900, or a Roland tape echo. There was an A/B switch that could send different signals to the 2 different amps. One Fender and one Vox.
I could mix and match them depending on the project.
Since I updated my setup a few years ago and replaced the rack effects with Eventide and Strymon pedals it is much more compact, but still modular. Or can be.
I have a big board that goes in a flight case that has an expression pedal and all my modulation and time based effects. Mounted on that board is a mini Pedaltrain that holds my dirt pedals. It can be removed and easily transported in the Pedaltrain gig bag. I usually bring along my DMM for echo duty.
2020 and lack of funds kept me from getting a 2nd Pedaltrain that would hold more of an experimental group of synth-fuzz, bit-crusher row of pedals that I could swap out with the standard fuzz board.
blunderbuss wrote: ↑Thu Dec 31, 2020 5:15 pmI was messing around with something along these lines earlier this year. Only using my splitter to have an effects channel and clean channel with light drive swapped polarity into my Deluxe Reverb. I may try something like this again but I just really like channel 2.
LOVE it!! Thanks for the feedback. Maybe I'll just try it one of these days. I'm afraid that I'm gonna like a separate board for each amp though. If I do, and want to make it permanent, there are some sounds that I quite love that I won't be able to get. But I like the idea of changing it up for a little extra inspiration too...blunderbuss wrote: ↑Thu Dec 31, 2020 5:17 pmOh and totally. Split pedaltrain nano boards with chainable Cioks power supplies are fun. But I’m just using one atm.
