Servicing an old Rat?
Has anyone here done service work to their old Rat? My early 90's one has started popping a little when switching so I suspect one/some of the electrolytics have gone bad (but I will change the switch again first, just in case)
From what I'm reading here I should be mainly looking at C7 and C10 (and possibly C5 & C6) as those appear to all do DC blocking in some way? Or should I just do all of them now it's 27 years old?
Any advice would be rad
JS
JS
- øøøøøøø
Re: Servicing an old Rat?
I don't see a switch on the schematic.
I'm not a Rat expert--is this a mechanical bypass switch? Buffer amp?
Pull-down resistors to and/or from switch?
Yeah, it's mechanical (true) bypass. DPDT switch but and early form of millennium switching for the LED
- øøøøøøø
The components surrounding the switch are the most important for us to see to diagnose your problem (this includes associated circuitry of the LED indicator).
- øøøøøøø
In any case, I'm not sure I'd be looking at a failed electrolytic capacitor as a suspected cause of switch pop, but it generally doesn't hurt to replace them.
I wonder about the switch itself if we're sure the circuit was formerly working fine without popping. Sometimes an old switch can "bounce" just enough to act like a capacitor for a split second and "charge up" a tiny touch of offset voltage.
Here you go.
It is a very particular setup (and quite advanced for its year)
- øøøøøøø
Interesting.
I think I’d try replacing the switch.
This is a bit out of my area of expertise (try asking on GroupDIY) but if the switch was “bouncing” a lot I wonder whether it may develop a charge through that 22M resistor
- øøøøøøø
One other thing I thought of just now—try disconnecting the LED by lifting one leg.
Does it still pop?
If not, try replacing C11 and C13.
If the LED were to draw a sudden bit of current, it’s not inconceivable that it could cause a pop if the power supply wasn’t handling the sudden draw well
Does it still pop?
I did the switch this morning, still popping. I was short two of the right size caps so have ordered them up and I'm going to change all of the electrolytics in one hit: C5, C6, C7, C10, C11 & C13. The led is hot glued in place (which gloops over the IC chip too) so I'll try and leave that be if possible and see if the cap swap does the trick. Theoretically, with a new switch and caps then no DC should be getting where it shouldn't. I ran a MM on them all and C7 is letting approx 2.4mV through, a couple of the others are >1mV, the rest more like 0.1mV.
Apart from a previous footswitch swap it's done very well considering I've been stomping it into oblivion for 27 years.
- øøøøøøø
C1 and C10 (actually C9 before) should be blocking any theoretical DC offset from a leaking C7, but it doesn't hurt to swap it anyway.
Let us know how it goes.
I suspect C11/C13 maybe? reduced capacitance could theoretically cause challenges recovering from an LED turn-on.
One question--the pop occurs whether powering from battery or external supply?
It occurs off both battery and PSU. I use a battery 99% of the time.
- øøøøøøø
Let us know what happens after changing the caps! I'm very curious about this
- MrShake
Definitely. I haven't had any trouble yet, but I've got a couple coming up on 30 years old, so this kind of thing may become more common. Thanks for keeping us updated so far!
Okay. So today is my day off and I set about swapping all the electrolytics. I just used some audio grade Nichicon UFW caps:
Annoyingly, it still pops My 1984 White Face does not. My only assumption now is that the 2N5457 transistor is at fault somehow. I have found one example online of someone replacing that in a Rat, along with the caps, and it solving the popping problem
- øøøøøøø
It's annoying to need to replace one transistor if you don't have them on hand already. You either find yourself buying way more than you need, or paying $10 in shipping costs for a $0.20 part, or contriving a bunch of other stuff to buy to make the shipping worth it.
