Budget multi-fx headphone amp?
- sal paradise
I’m stuck away from home for a while. Rather than get a traditional amp, was thinking are there are any good options for a budget multi-fx type thing with amp/cab sim & headphone out that I can just plug in & play in the house? Extra points for manual controls & minimal computer editing.
- GreenKnee
Re: Budget multi-fx headphone amp?
Line 6 Pocket POD Multi FX
https://reverb.com/item/52452225-line-6 ... t=52452225
£99 new, could be a bargain if you find a used one
- sal paradise
Ah, perfect! Cheers
- cestlamort
The old Boss ME5 has a headphones out that is decent - no amp sims but the effects are all good to great.
- Lost In Autumn
perhaps too much computer fiddling required, but this seems pretty simple:
https://www.fender.com/en-US/guitar-amp ... 00000.html
- Dollywitch
The Nux Mighty Plug for sure, the new version has a ton of features. The lack of knobs sucks for these things of course, you do get more with the Fender one but also have set effects blocks.
- sal paradise
Little update. Came close to pulling the trigger on a pocket POD, and then I came across a video for a cheapo chinese thingy.
£30 & it sounds awesome. Plus it’s got switches & it’s got a rechargeable battery. It’s so little, I’m quite amazed at both the sim quality & the amount of stuff onboard
- Dollywitch
What, that looks cool as shit. I'd consider picking one up as a recording interface. The IR feature could be useful too.
- 1452L
Where did you get it for £30?
- UlricvonCatalyst
Was going to recommend you look for an old Zoom H4, which doubles (or should that be multi-tasks?) as a field recorder and 4-track, as well as doing multi-fx, USB I/O, etc. but I guess you're sorted. Often available cheaply if anyone else is on the lookout for such a thing.
