Hello!
I need help with finding an autofilter pedal to play live; problem is my new recordings use a logic autofilter that I mess with, but none of the pedals I've tried out so far get the same sort of swooping noise, over a few bars, or the glitchy wheeps, either.
Any suggestions??? See below for parameters of the filter I'm using.
All help much appreciated. The autofilter in the Helix LT I use is quite good, but more tank-like, less kinetic.
Help needed with autofilters
- FrankRay
- fuzzjunkie
Re: Help needed with autofilters
It’s not a pedal but I use something called a Filter Queen, it’s a mini version of the Electrix Filter Factory. I don’t think a basic (3-4 knob) pedal will include all those parameters.
You’ll probably also have to decide between analog and digital filters.
I always wanted to try the Death by Audio Evil Filter. https://deathbyaudio.com/products/evil-filter-1
Source Audio makes an envelope filter that covers a lot of bases.
Of course there’s the Electro Harmonix Q-Tron if you want something mass produced.
- FrankRay
Thanks!! I'll check them all out.
