EarthQuaker Devices Aqueduct vs Boss Vb2w
- Brock the Mod
Anyone got experience with either or?
They both sound and look good.
- shoule79
Re: EarthQuaker Devices Aqueduct vs Boss Vb2w
I have the VB-2w, and am a big fan of it. Specifically I like the latch feature and how it seems to add a bit of sparkle to my signal overall. It does the worn out VHS sound too, but the wave form is consistent. I have two typical uses for it; 1) subtle slow vibrato on my clean signal to add some movement to chords and such, and 2) keeping it on latch mode and adding vibrato when I need/want it by pressing down on the switch. This is fun with fuzz.
Its probably not going to go as slow as a newer vibrato, if that is something you are looking for. Its fully counterclockwise speed is my Julia at about 9 o'clock. Its also just one wave form, where the Aqueduct appears to have several (the Julia even has 2). The Aqueduct is also digital vs the VB-2w, if that matters to you.
- Brock the Mod
I mean the VB2 is on countless albums I like.
But the aqueduct seems to over more wave forms and i saw a video of it and it sounded good.
Distortion wise though you like it with the VB2w?
- bubba899
I've played both and went with the VB-2w. I really liked the random mode on the Aqueduct, thought that was the main benefit of it over the VB-2, but the overall sound wasn't as good for me, felt a little less fluid ironically, Might just be how I had it set up though. There's not really much in it, but that's my two pence.
I may also be just too set in my ways as before the wazza VB-2, and even since it, I've had a Behringer UV on my board so it's just what my ear wants to hear.
- Brock the Mod
Thanks for the input my manbubba899 wrote: ↑Wed Jun 30, 2021 2:37 amI've played both and went with the VB-2w. I really liked the random mode on the Aqueduct, thought that was the main benefit of it over the VB-2, but the overall sound wasn't as good for me, felt a little less fluid ironically, Might just be how I had it set up though. There's not really much in it, but that's my two pence.
- tdbajus
The VB2W is awesome and I love it.
The buffer on it seems to be a cut above the usual boss stuff. There's very little documentation on it, which is weird. I wish my guitar sounded as good going through my old DD2. I love those echos, but boy it is a tone killer.
I'm half convinced that my guitar sound better going through the VB2W [edit: even with it off].
- shoule79
I do, but I’ve mostly used it for leads with a muff or Rat type pedal. I’m always at least running an overdrive though.
Like someone else said, my guitar seems to just sound better with it in my chain.
- kingmedicine
I’ve owned both, but kept the VB-2w. Sounded more “natural” to me and more in line with the vibrato sound I hear in my head. The Aqueduct was very versatile (the VB-2w seems like a bit of a one trick pony…but it’s a very good trick), and the random mode was a lot of fun for wall-of-sound type stuff, but I didn’t like the more standard modes much. I also thought the Aqueduct had a little bit of latency that I did not care for either (although I’ve seen conflicting reports of this online).
