I thought I'd ask in here...
Is there a vibrato pedal on the market that can be set that the pitch change only goes to the flat and back again on the LFO rather than flat/sharp/flat/sharp?
Vibrato pedal that only LFOs flat?
- fuzzjunkie
Re: Vibrato pedal that only LFOs flat?
No, I’m not aware of any Vibrato pedal that does this.
However, almost any pitchshifter with an LFO can.
I have 2 rack mounts and an Eventide pedal that have algorithms where you can set the amount of pitch shifts up and down with an LFO control.
I don’t set them flat only, but I might give it a try? Never thought of that before. I don’t always make them symmetrical though. For instance I have one setting that has : 17ms pre-delay | pitch-1 +5cents | pitch-2 -7cents | LFO speed 3.2 Hz. That’s more of a slow chorus than vibrato.
Asymmetrical shifts sound more interesting to me. Greater flat settings do sound darker, while greater sharp settings have more chime.
- fuzzjunkie
Not exactly sure what sound you’re going for, but maybe a simple detune pedal would work? No LFO, but you can pitch shift your signal down a few cents and get some cool sounds. Digitech Luxe, is one option there:
https://m.youtube.com/watch?v=P4FBDiFUW0Y
Same idea, but with LFO and more complex controls; maybe something like the Red Panda Particle, or Chase Bliss Warped Vinyl? The next step from there is going to be Eventide, either H9 or Pitchfactor.
- jorri
Its also that detuned notes will amplitude LFO themselves, due to 'beating'. A different sound, but they certainly dont remain static, the Hz difference is the rate, essentially because waves dont align and momentarily phase cancel.fuzzjunkie wrote: ↑Mon May 31, 2021 1:12 pmNot exactly sure what sound you’re going for, but maybe a simple detune pedal would work? No LFO, but you can pitch shift your signal down a few cents and get some cool sounds. Digitech Luxe, is one option there
- fuzzjunkie
Yes, the Luxe and similar pedals create sounds from ADT to Univibe tones. Even pseudo 12 string.jorri wrote: ↑Mon May 31, 2021 2:18 pmIts also that detuned notes will amplitude LFO themselves, due to 'beating'. A different sound, but they certainly dont remain static, the Hz difference is the rate, essentially because waves dont align and momentarily phase cancel.fuzzjunkie wrote: ↑Mon May 31, 2021 1:12 pmNot exactly sure what sound you’re going for, but maybe a simple detune pedal would work? No LFO, but you can pitch shift your signal down a few cents and get some cool sounds. Digitech Luxe, is one option there
Thanks for the suggestions. I'm not much into really complicated setups so anything that isn't a simple stomp confuses the hell out of me.
I don't think there's actually anything out there that does what I've got in my head, and I mostly use vibrato as a subtle background effect so I've decided just to stick with what I've got for now and live with it
