Delay Pedal with Vol and Mix
- Beebe
Anyone know of a standard size delay Pedal with Volume and Mix or Blend control? I see the JHS Panther Cub does, but wondering if there is something less expensive.
Without music, life would be a mistake.
- ElephantDNA
Re: Delay Pedal with Vol and Mix
What is our price range? The answers are going to be really different if we have $50 or $150 to spend here. Also analog vs digital?
The first thing that comes to mind is Tech 21 Boost DLA which is digital that tries to sound like analog. It definitely has a master volume and a blend knob and sounds good. But I always like tech 21 so maybe I'm biased in that way. Used to be able to get those around 100 bucks but just looking quickly here it seems people are starting to ask more now. Probably because they don't make it anymore.
- fuzzjunkie
Wait, what?!?
Am I misunderstanding something? Because I have never used a delay pedal that didn’t have Volume and Blend/Mix controls. Are there actually pedals that don’t, and more importantly, why wouldn’t they?
Edit: I see that OP is asking for a standard size pedal. I guess the 3 knobbers like the Ibanez AD-9 don’t have a volume control. My first delay pedal was, and still is, an EHx Deluxe Memoryman, but that’s not standard size. Well, it was in the ‘80s! All of my current delays have both controls, and I wouldn’t want one that didn’t. Good luck with your search OP.
- Beebe
Thanks! I also like Tech 21. I'll look into it for sure. I like analog in concept, but I'm not anti-digital if it sounds good.ElephantDNA wrote: ↑Mon Apr 26, 2021 6:10 pmWhat is our price range? The answers are going to be really different if we have $50 or $150 to spend here. Also analog vs digital?
- Beebe
Yeah it's crazy. The new ones offer all kinds of features and little knobs and switches for who-knows-what, but no level control.fuzzjunkie wrote: ↑Tue Apr 27, 2021 8:43 amWait, what?!?
- Beebe
And I don't mind spending some money on it, so $150 would be fine. The Panther Cub is $300 which is a bit pricey.... maybe not for 1000ms of analog delay, but I don't need delay times that long.ElephantDNA wrote: ↑Mon Apr 26, 2021 6:10 pmWhat is our price range? The answers are going to be really different if we have $50 or $150 to spend here. Also analog vs digital?
- Beebe
To explain what I'm going for: I'm currently using the Memory Toy which has mix, and sounds good, but no level. I used a setting when recording where I had the delay signal louder than the dry. I was able to mix the part loud in Cubase, but live it's getting lost.
- ElephantDNA
He wants one that has effect volume, mix, and also a master volume. So, some do and some don't in standard size format.fuzzjunkie wrote: ↑Tue Apr 27, 2021 8:43 amWait, what?!?
- Beebe
I haven't used one with Effect Volume, I assume it serves a similar purpose as Mix. So I don't think I need Effect Volume and Mix. And Effect Volume would only work for me if it allows you to turn the delay signal louder than the dry. And then I want the Master Level / Volume control to turn the whole thing louder when I kick the Delay pedal on for a "solo" part. So I just need knobs for:ElephantDNA wrote: ↑Tue Apr 27, 2021 11:25 amHe wants one that has effect volume, mix, and also a master volume. So, some do and some don't in standard size format.fuzzjunkie wrote: ↑Tue Apr 27, 2021 8:43 amWait, what?!?
1. Delay Time
2. Feedback
3. Mix/Blend (maybe Effect Level)
4. Volume/Master Level
- ElephantDNA
Got it. Yeah delay controls can be all over the place. Some give you more control over time, some more control over repeats or quality of repeats, it's kind of all over the place. But not many have a boost type of quality. The tech 21 is the only one that immediately comes to mind. Though I'm sure there is some weird boutique thing I don't know about that probably does this.Beebe wrote: ↑Tue Apr 27, 2021 12:19 pmI haven't used one with Effect Volume, I assume it serves a similar purpose as Mix. So I don't think I need Effect Volume and Mix. And Effect Volume would only work for me if it allows you to turn the delay signal louder than the dry. And then I want the Master Level / Volume control to turn the whole thing louder when I kick the Delay pedal on for a "solo" part. So I just need knobs for:ElephantDNA wrote: ↑Tue Apr 27, 2021 11:25 amHe wants one that has effect volume, mix, and also a master volume. So, some do and some don't in standard size format.fuzzjunkie wrote: ↑Tue Apr 27, 2021 8:43 amWait, what?!?
1. Delay Time
2. Feedback
- soggy mittens
Tall order, especially in a small format. I'm struggling to find any that are even in a larger format, other than JHS and ...
- jorri
DBA echodream has master vol and delay vol. It seems to be boosting or fuzzy.
Yeh, also many multi-fx style pedal has sime kind of patch level.
But understanding what you want, maybe this is why delays feature level with no mix, especially the standalone analogue-style ones. (Other than in analogue mix control are kind of disappointing/more complex than youd expect and feature volume drops etc.) The ones i have use with a level control boost the delay well above unity - they have the inverse problem in fact of getting wet-only sounds. You'd have to have the boost, and still be some dry even if its down by 12db or howeve if you wish to have something near wet (like 90% wet) it would come with such boosting.
- Beebe
It just seems crazy to me. Anyone who has ever done any mixing has surely pushed up the level fader for the solo and there is a pretty good chance they added some delay as well. It seems like solos would be one of the primary uses of a delay pedal. I might look into modding my Memory Toy pedal with something like this:
https://guitarpcb.com/product/after-bla ... ain-stage/
- Beebe
Based on this... it actually sounds like one of the pedals with an "Effect Level" control might work for my particular application where the wet is louder than the dry. But it would be better to have mix and level so you can use the pedal as a clean boost and to add a bit of delay to spice up a solo or single string parts. I did come across one with a 3 dB boost dip switch... I don't remember what it was though, and 3dB might not be enough of a boost for a solo type situation.jorri wrote: ↑Wed Apr 28, 2021 4:38 amDBA echodream has master vol and delay vol. It seems to be boosting or fuzzy.
The Belle Epoch has an internal trimpot.
