Can anyone suggest a good Bass overdrive/distorton pedal?
- timiscott
I'm looking for a bass OD or similar that'll work well with an Eden WTDI box. I'm looking for JJ Burnel type rasp and rattle.
Re: Can anyone suggest a good Bass overdrive/distorton pedal?
Tronographic Rusty Box or something Rat flavored with a clean blend like the Jam Pedals Rattler Bass.
- timiscott
I'm really hoping this is not a 'you get what you pay for' situation! I was thinking about the Ampeg Scrambler but I won't jump if it's not great. I got an MXR Timmy and it's great, so I was thinking there must be something great out there in that price range. Any ideas?
- Dr Tony Balls
Tooting my own horn here, but it DOES check the boxes mentioned above. Rat-adjacent with multiple clipping options and a clean blend. My personally preferred bass distortion.
Instagram: thetonyballs
- burpgun
I'm probably the only person out there who will pitch the Ashdown Lomenzo Hyper Drive. You can find them pretty cheap used and they've got that VU meter thing Ashdown loves. I'm not a fan of the full on distortion sound, but the controls are great at allow you to add some top end very adjustable dirt while preserving the punch of the clean signal. My only beef is the pedal could be a lot smaller than it is.
- ElephantDNA
I will always say Rusty Box or Tech 21 Bass Driver. I feel like this thread comes up sometimes and I have yet to find anything that I like better than those two. To be fair I don't know what this eden thing does or doesn't do though.
- Pepe Silvia
I have a Microtubes 500 so it has the vintage and b7k built in. The vintage is a nice warm overdrive, b7k can get quite gnarly.marqueemoon wrote: ↑Mon Mar 15, 2021 12:57 pmEh, for bass I’m a bit snobbier.
I use a Darkglass Vintage Microtubes myself. I love it, but probably too polite sounding for what you’re going for.
Pepe Silvia wrote: ↑Mon Mar 15, 2021 3:58 pmI have a Microtubes 500 so it has the vintage and b7k built in. The vintage is a nice warm overdrive, b7k can get quite gnarly.marqueemoon wrote: ↑Mon Mar 15, 2021 12:57 pmEh, for bass I’m a bit snobbier.
They make good sounding stuff and there is a healthy used market for it.
- fuzzjunkie
A Rat type is the more common answer, but I like a Tonebender Supa or Jumbo. They are basically a Big Muff with less clipping, and while they don’t have a clean blend, they sound like they do. There’s some sort of low pass filtering going on that lets the bass cut through.
- bubba899
Our bass player really likes that Ampeg Scrambler drive pedal, sounds good to my ears.
- s_mcsleazy
i have a proco juggernaut. it's pretty rad
- MechaBulletBill
wh pork loin
ssbs mini
ehx bass big muff
my gf (more of a bassist than me) uses a clone of the old ampeg scrambler fuzz w/ clean blend - scrambled brains
i had an mxr distortion+ modded with different cap values that KILLED on bass, so maybe something like the eqd gray channel
ssbs mini
ehx bass big muff
- jorri
I've tended to use the Fulltone OCD clone Mooer Hustle Drive. they were intended for bass as well, the circuit is designed to clip the lower frequencies less.
Muffs are good. I played in a band where the bassist's 'bass big muff' was already enough without engaging the 'bass mode', in stock setting.
Rats need a clean blend there is little in the way of bass frequency in them. Well, a lot more can work with a clean blend to be honest!
Stranglers used a guitar amp. Maybe try a guitar amp sim into bass amp, i'd imagine that could sound great.
- HarlowTheFish
I've been running a Plexi amp sim with a bit of grit, then blending three ways between the Waves Berzerker, the Ignite Amps Pro FET, and clean to get some good coverage. Probably way crazier gain than you're looking for, but it's real flexible.
If you need a pedal, something with a clean blend or some sort of bass bypass is gonna be pretty important to get some good low end. Jorri's suggestion of running some kind of cranked guitar amp to blend in is also pretty good, it'll get you some nice growly midrange and let your bass amp handle the low end and dynamics.
