I've got a pair of these Eminence speakers made for Fender (model 121042 is written on the magnet sticker) that I believe are used in the Hot Rod Deluxe. They're 8 ohm and I believe rated at 75w (one auction for them said 60w but I'm not sure which is correct).
I've got them for sale locally and a guy called up to ask me some questions about them. The main one which I really couldn't answer is:
Will a pair of these, set up to run as a pair at 4 ohms, be suitable for a Twin Reverb (I think it's a 100w silverface but it could be the 85w reissue, not sure)
Thanks
Pair of these Eminence/Fender speakers ok in a Twin Reverb?
- mjet
- luau
- Admin
Re: Pair of these Eminence/Fender speakers ok in a Twin Reverb?
Not quite the same, but I've had a pair of 8 ohm Vintage 30 Celestions (60 watts apiece) running in parallel at 4 ohms in my 105watt TRII for a decade without issue. Provided that the wattage of the pair is greater than or equal to the rating of the amp, I would think they would work fine.
Bigger in sum than parts.
- Surfoverb
Yup thats what I have in my TRRI.
- afunkymonk
They are sold by eminence as "legend 125" - they are reviewed on harmony central, although one bloke claims they are different, everything else I've read says otherwise,
http://reviews.harmony-central.com/revi ... d+125/10/1
By the way, I put a neck on your musicmaster, and fitted a jaguar pickup - number 1 guitar for studio sessions at the moment
Why is Spain? Where are the Snowdons of yesteryear?
- OffYourFace
that's what comes in the '65 twin reissue, same speakers. will sound great!
- Surfoverb
Ive got the blonde TRRI which has the Eminence, but I think the 'regular' twins have the Jensen speakers.OffYourFace wrote: that's what comes in the '65 twin reissue, same speakers. will sound great!
- Parka
Exactly what I was gonna say !OffYourFace wrote: that's what comes in the '65 twin reissue, same speakers. will sound great!
For what its worth Vintage 30s are my favs in a twin - that my my 2 cents anyhoo..
