Downsizing amps
Make it loud here.
JSett
Re: Downsizing amps
Post by JSett » Thu Jun 01, 2023 9:05 am
Dr Tony Balls wrote:
Thu Jun 01, 2023 9:00 am
JSett wrote:
Thu Jun 01, 2023 8:44 am
As for the Vox I thought my AC15 (a 2009 one) sounded pretty damn close to my old AC30 (a Korg one) with a little knob-twiddling
That's *probably* an AC15CC1 which is more similar to a top-boost AC30 circuit, but not identical. Sound-wise it may do the trick just fine, i'm just talking specifics.
Yeah, it was a CC1 or CC2, I can't remember exactly. Sounded great and was a good size for home use (although still quite loud in my little house).
Dr Tony Balls
Re: Downsizing amps
Post by Dr Tony Balls » Thu Jun 01, 2023 9:18 am
although still quiet loud
LOUD quiet loud?
Instagram: thetonyballs
JSett
Re: Downsizing amps
Post by JSett » Thu Jun 01, 2023 9:43 am
LOUD quiet loud?
Quite
Damn you autocorrect!
fuzzjunkie
Re: Downsizing amps
Post by fuzzjunkie » Thu Jun 01, 2023 10:51 am
Thu Jun 01, 2023 7:31 am
In any era that Dick Denney would be concerned, the AC15 is very different than the AC30. When you start getting into later reissues there may be other version that truly are half powered AC30, but not the originals by any stretch. AC15s in the 60s didnt have a non-EF86 normal channel and nothing was "top-boosted"... only the EF86 channel and the vibrato channel.
Ed: not calling Tony out. Just want to confirm the historical facts. I knew he was 90% right with his evaluation but I also knew that the AC30 had an EF86 preamp early on. I didn’t know the AC15 started out with an ECC83, I thought that changed after the AC30 switched over, but I did know that amp has had some different preamps like the AC30 and the current models do as well, or rather the 12AX7 named version of that tube.
I realize that the early AC15s didn’t have a Top Boost channel and that the AC30 didn’t either, but I thought they shared the same circuitry until the Top Boost was added to the AC30 in late 1963 after being an add-on option.
After looking at a couple of Vox history pages it looks like the AC15 originally had an ECC83 preamplifier before Denny changed it to an EF86 circuit in the single speaker TV version of the amplifier. Supposedly he included the Vib/Trem channel because the power amp was based off a JMI organ amplifier.
When the Shadows and other groups wanted more volume he introduced a Twin model with 2 speakers and eventually the AC30.
According to both articles I read, the original version of the AC30 was an EF86 preamp taken straight from the AC15 and he doubled the power amp and used the twin speaker configuration.
He rebuilt the preamp with ECC83 after issues with the EF86 caused by inefficient output and higher volumes. So for a short period the AC30 was a more powerful version of the AC15 but the preamp valves were prone to rattling, overheating and microphonic, so he was forced to change them.
Since Korg took over in 1993 the AC15 has had both a Normal and Top Boost channel with ECC83 preamps; so definitely not like the original version and more of a half powered AC30, except for a few limited edition models such as the ‘59 TV AC15 which has the EF86 preamp like the originals.
marqueemoon
Re: Downsizing amps
Post by marqueemoon » Thu Jun 01, 2023 3:21 pm
If you are looking for EF86 Winfield is worth a look.
I am often tempted by their Typhoon head which is basically an EF86 AC4.
Funkybot
Re: Downsizing amps
Post by Funkybot » Thu Jun 01, 2023 3:36 pm
I've got a Vox AC15C1X (the X just designates it's got the Celestion Blue). Lyle from Psionic recommends this model over the CC. Easier to mod and repair and built better from what I recall. Includes reverb, trem, and importantly, a good master volume. If I were looking to downsize (down volume) from a Korg-era AC-30 (which are great amps) that should be high on the list.
If anyone has a TONEX, I profiled my amp at various settings and posted those. Then volume is really a non-issue. Seriously, I love amps, but for home use, those profilers are killer.
fuzzjunkie
Re: Downsizing amps
Post by fuzzjunkie » Thu Jun 01, 2023 3:47 pm
I did look into those last year because I thought I would like the EF86 based off the description of being dynamic, raw and chimey , but after hearing one (in a Dr Z) I think I prefer the ECC/AX preamp with Top Boost. The modern AC15 covers that. Maybe if I played a Winfield or Vox with an EF86 I would feel differently?
It’s similar to preferring the tone from a Princeton over a Deluxe. A lot of people love the Deluxe.
marqueemoon
Re: Downsizing amps
Post by marqueemoon » Fri Jun 02, 2023 12:54 pm
I am pretty indifferent myself. I have yet to hear an EF86 based thing that has absolutely sold me on it. A low watt handwired simple/inexpensive Vox I could crank up is the main appeal of the Typhoon for me.
For what the Cyclone costs there are other AC15 options worth considering I think.
Re: the Princeton vs. Deluxe thing the answer for me has been a Swart AST. It’s a more Gibson-derived design and is more mid-forward, but in terms of volume and headroom it sits perfectly in the middle. The perfect club amp IMO, and still sounds great at more moderate volumes.
DeathJag
Re: Downsizing amps
Post by DeathJag » Fri Jun 02, 2023 1:46 pm
I apologize if this was already addressed (I kinda gloss over modeling talk), but why not just get a couple of good attenuators and keep the big tubies? I could not be happier with the two that I've got, use em with a Twin and Bassman for a wet/dry rig. And boy do I have snobby ears haha!
fuzzjunkie
Re: Downsizing amps
Post by fuzzjunkie » Sat Jun 03, 2023 8:08 am
No, it hasn’t, but I hadn’t really considered it. I’ve never used one myself, but friends using Hot Plates to cool down Matchless and Vox amps always complained about the result.
That was over a decade ago and maybe the tech has improved? What are you using?
JSett
Re: Downsizing amps
Post by JSett » Sat Jun 03, 2023 8:35 am
I don't know what Dan is using but I've always had great results from the Weber attenuators.
Surfysonic
Re: Downsizing amps
Post by Surfysonic » Sat Jun 03, 2023 9:23 am
I use a Weber Mass 200 (200w) Attenuator - it's awesome. :)
https://www.tedweber.com/mass-200/
DeathJag
Re: Downsizing amps
Post by DeathJag » Sat Jun 03, 2023 10:41 am
Yep, that's one of em - that Weber Mass 200. It's not very expensive either! The other one I use is the SPL Reducer, which is more expensive and sounds identical. The Weber has some reactive element that the SPL doesn't. The Reducer is a bit pricey. I actually prefer the Weber because I love its huge rheostat knob, and the bypass switch. Both sound totally transparent. It's pretty hard to get an accurate test because you either have to turn the amp down which changes its characteristics, or turn it up and barely use the attenuator. I do record though, and the recordings sound just like when the amps are turned up without an attenuator.
Maggieo
Re: Downsizing amps
Post by Maggieo » Sat Jun 03, 2023 11:06 am
I have a Swart Night Light, that I use on my Secret Agent. Oh, and my Milkman has a built-in one that is really, really, amazing.
If I had a big, loud amp that I loved, I think I'd get a UA Ox Box. AC30 into one of those? I've seen enough Y/T vids to know that sounds GREAT.
marqueemoon
Re: Downsizing amps
Post by marqueemoon » Sat Jun 03, 2023 11:17 am
I borrowed a friend’s OX for some overdubs. It was… ok.
I don’t think I would buy one based on that experience.
