New Amps Day
- ThePearDream
New Amps Day
I picked up two amps today! I've really ignored building up my amp collection and had been wanting to add a loud clangy solid state amp and also some king of small, tweed-like, two knob, tube amp. I haven't had a real tube (or solid state) amp in years. I've mostly used digital-tube hybrids for 15+ years (Johnson Marquis, Vox AV, etc.), so I'm looking forward to diving in to these.
First, for the clangy solid state amp, is a Yamaha g50-112 II combo. Very loud, very nice clean, the gain channel isn't even too bad. Missing the Yamaha badge. Needs a new reverb pan, I think. I plan for this to be my main pedal amp now.
Then for the small tube amp, I picked up a VHT Special 6 combo. With the hand wired eyelet board, it seems like a really good, affordable option for learning how to do amp mods. I'm plannning to get a mod kit to turn it into a 5F2A Princeton. The amp plus a mod kit is way cheaper than buying even a small amp kit.
I still really want a Princeton Reverb and a Vox AC15, but I'm feeling a lot better about my amp collection now.
Doug
@dpcannafax
@dpcannafax
- ThePearDream
Re: New Amps Day
I think I see the problem with the reverb tank. Good thing I had them knock $50 off.
Doug
@dpcannafax
@dpcannafax
Re: New Amps Day
Nice. I had a Special 6 head for a while. They are pretty fun.
- MrShake
Re: New Amps Day
Congrats, I bet those two are going to make a nice coplimentary pair!
- panoramic
Re: New Amps Day
those old yamahas are really quite nice.
- ThePearDream
Re: New Amps Day
Thanks folks!
So, the reverb tank I pulled out is a non-original 4BB2D1D. There isn't a ton of info out there, but it seems like the original was maybe a 1AB2C1A. I don't know enough to know if the different input impedance or connector or mounting orientation codes allowed this tank to work correctly or not. Anyway, once I found out a suitable replacement for the original, I adjusted from there to get a longer pan and long decay and have ordered a MOD 9AB3C1B pan. Looking forward to hearing these really great clean tones with that big spring reverb pan. I also need to figure out footswitch for the reverb.
Also, the parametric EQ is clearly a really powerful tone sculpting function, I can't wait to explore this part more.
Doug
@dpcannafax
@dpcannafax
- BoringPostcards
Re: New Amps Day
Yea, they really are. The guitarist in one of my old bands used one. He got great tones out of it in our noisy little band.
- panoramic
Re: New Amps Day
Fender stage 160 2x12 SS amps are also a good deal and similar in overall sound. I played both in the 90's and was happier with them than my peavey classic 4x10 combo. I gigged with a 50 watt jcm 800 then, i miss that thing.BoringPostcards wrote: ↑Thu Feb 16, 2023 4:22 amYea, they really are. The guitarist in one of my old bands used one. He got great tones out of it in our noisy little band.
- ThePearDream
Re: New Amps Day
I got the new reverb pan installed yesterday. It sounds super sproingy now.
After consulting a circuit diagram for the amp, I bought a simple on/off footswitch from Saturnworks on Reverb. Works perfectly for the reverb or channel switching.
The mod kit for the VHT is on the way, as are a pair of NOS tubes.
Doug
@dpcannafax
@dpcannafax
