Quiet Night Practice Solution
Make it loud here.
Larsongs
Post by Larsongs » Sun Sep 25, 2022 5:54 am
What’s yours?
Someone mentioned using a Distortion Pedal with the Level turned to almost Nil or 0.. I gave this a try last night..
My Amp Volume between 5-6 & other Settings are set as usual. I turned the Level to 0 on my Ibanez TS-808 Tube Screamer.. Then I barely turned it up & it works! I still get the same Sound as usual. Just at very low Volume.. I tried different adjustments on the Gain knob from Clean to Max Distortion.. It worked!
Cost nothing..
stevejamsecono
Re: Quiet Night Practice Solution
Post by stevejamsecono » Sun Sep 25, 2022 1:36 pm
I got a Yamaha THRII with a headphone out. Works like a charm!
Prior to that, I'd play unplugged or into a Boss ME-50 with headphones and it sounded pretty good too.
It's so hard to understand
Resident Yamaha Fanboy
COYS
JackFawkes
Post by JackFawkes » Sun Sep 25, 2022 4:15 pm
I also use a Yamaha THR-II. Have had it for about two years now and love it, great sounds through either headphones or its built-in speakers. Dial the amp of your choice in however you like, and the Guitar Output knob lets you control the overall volume perfectly.
Jack
øøøøøøø
Post by øøøøøøø » Sun Sep 25, 2022 4:48 pm
Anything that lets you use headphones. Even DI into a GarageBand amp sim should be fine for practice
marqueemoon
Post by marqueemoon » Sun Sep 25, 2022 5:47 pm
I usually just play electric unplugged at home.
The OP’s tip is a good one though.
Larsongs
Post by Larsongs » Thu Sep 29, 2022 9:07 am
I do that too.. That is by far the easiest without a doubt.. But, no real Sound or FX.. But, still very cool to do..
I also have Logic Pro X. I run my Guitar thru my Clarett 8 Pre Interface & use Logic’s Guitar Amp Plugins & FX then listen through Headphones.. It is pretty amazing all the Amps, Spkr Cabs, Mic’s for the Spkr Cabs & the Infinity Pedalboard.. The possibilities are endless!
