new old amp day
a friend give this little gizmo
it was not working and after look at it is just the inner fuse that was blow ,need to source one and also put some thermal paste on some transistor cause it seems to heat much (transistor are put on the frame with thermal past and with a nylon screw )
the pots crackle a little but it is funny past 4 the reverb is intergalactic !, the clean is clean and the overdrive is like is name ,zz top range not heavy metal
nice thing to plug when you don't want to plug the big other
NOAD
- Maggieo
Re: NOAD
Cool!
