Pathfinder 15R Repair
- secondhand
Very low signal. Can barely hear my tonez with vol and gain maxed. Internet always points to replacing the octocoupler with pics from a Cambridge. My board and components look different.
You can see it here until I figure out how to add an image.
Vox Pathfinder 15R made in Korea https://imgur.com/gallery/BiUbnr8
Any ideas how to fix it or links to better instructions?
Good as the best. Bad as the worst!
Re: Pathfinder 15R Repair
Hmm, I'd be doing the 'basics' like applying contact cleaner and lubricant (ie DeOxit/Faderlube) to pots, jacks and switches where appropriate first. Does 'working' the pots back and forth improve matters any?secondhand wrote: ↑Thu Aug 05, 2021 7:57 pmVery low signal. Can barely hear my tonez with vol and gain maxed. Internet always points to replacing the octocoupler with pics from a Cambridge. My board and components look different.
Optocoupler would only be relevant to the tremolo as far as I can tell(?)
- mackerelmint
Well, they use amplifying ICs, and it wouldn't be terribly surprising if one or more had shit the bed. I mean, obviously try contact cleaner first, but replacing the amp chips would be an easy thing to try and wouldn't cost much. If you've got a multimeter, you could get data sheets online and use those to test the voltages coming off the pins and see if they're in spec without having to buy anything first.
- secondhand
I gave the pots some cleaner and reflowed a solder joint that looked suspect on the trem depth pot but still no improvement.
I have a multimeter but don't really know how to use it. I think I have exhausted my skills and abilities with electronics trouble shooting.
Thanks for the suggestions though!
- mackerelmint
Well, in that case, try replacing the amp ICs. Socketing them while you're at it wouldn't be a bad idea. That's just simple soldering.
- MattK
You might want to look at the sockets on the back too. Something shorting the speaker out or headphone jack?
- secondhand
I gave the pots another shot of cleaner and while turning the treble pot the amp came back to life. Then died again.
I reflowed the solder joints but it stayed dead. I ordered a new pot. I hope the replacement pot will be the cure.
- MattK
