Who plays through a stereo rig??
- Lost In Autumn
Re: Who plays through a stereo rig??
I'm running stereo into a heavily modded Fender Blues Junior & 1 1-15 cab and a black panel Deluxe Reverb reissue. I play ambient/psych/bedroom/dream pop and to make the most of the stereo setup, I'm stacking reverb/delay pedals, Walrus Audio D1 & R1 into a EQD Dispatch Master to the Deluxe Reverb Left and into a OBNE Dark Star to Blues Jr, Right. The Blues JR is a little darker voiced and to emphasize that, Im using the OBNE Dark Star in Pitch Mode, with the controls at 11:00 & 1:00 to give it a warbly modulated reverb. it sounds dark and swampy, while the other channel is bright and sparkly. I also offset the delays to so that the note attack isn't synchronous, giving the impression of multiple guitars.
ive been using dual amps for many years
radial twin bones into a vox pathfinder and a peavey studio pro 50
sometimes i use two pathfinders. one is a head into a 1x12 cab and the other stock
i spread em out and put one in the center by the drums/ behind the singer
the louder amp is clean and the pathfinder is slightly dirty
- hulakatt
I've done a few gigs with 2 Champs in stereo, usually separated with a Fulltone ST2 and mic'd up separately. I'd love to try it again with a stereo chorus pedal as I've enjoyed that the most of the stereo effects I have at home. I also use the pair of Champs at home just for messing around with some stereo gear.
She/Her
- welshywelsh
- Larsongs
I’ve been using the Keeley 30ms Double Tracker.. Sounds xlnt with one Amp.. It really sounds great with 2 Amps for Double Tracked Stereo Sound… Check it out…
https://youtu.be/-3jTSw0grXg
- Rob
If you're like me in that you love stereo but don't always have the stage room for multiple cabs without vertical stacking, I highly recommend something like this.
This one's in a 410 so I can run it mono, or as pair of side-by-side 210s in the same cab.
- Larsongs
I’ve got a couple like that.. To my ears it sounds like 2 speakers playing the same thing. Sounds like Mono with 2 speakers.. There’s no dimension…
The Keeley adds Stereo dimension.. Not just 2 speakers sounding mono….
- Unicorn Warrior
I thought about getting one of the JC-40s to run in stereo with my matchless. But, if I like stereo, I would like the option to take it by itself and use the stereo that way as well to scale down how much I bring
That is a perfect setup The Dark Star is SO good with stereo/dual mono.Lost In Autumn wrote: ↑Sat May 28, 2022 3:40 amI'm running stereo into a heavily modded Fender Blues Junior & 1 1-15 cab and a black panel Deluxe Reverb reissue. I play ambient/psych/bedroom/dream pop and to make the most of the stereo setup, I'm stacking reverb/delay pedals, Walrus Audio D1 & R1 into a EQD Dispatch Master to the Deluxe Reverb Left and into a OBNE Dark Star to Blues Jr, Right. The Blues JR is a little darker voiced and to emphasize that, Im using the OBNE Dark Star in Pitch Mode, with the controls at 11:00 & 1:00 to give it a warbly modulated reverb. it sounds dark and swampy, while the other channel is bright and sparkly. I also offset the delays to so that the note attack isn't synchronous, giving the impression of multiple guitars.
- Rob
The speakers themselves are different (creambacks and golds), and the L/R inputs are coming through a Boss DC-3 for dimension. Sounds great to my ears.
- Lost In Autumn
I was underwhelmed by it on its own, I loathe shimmer reverb and the delay verb was not entirely different from my dispatch master, but I read a suggestion about putting the dials at 11 and 1:00 in the pitch shift mode for a modulated reverb and it’s given the left channel a unique voice that really enhances the stereo spread.Shadoweclipse13 wrote: ↑Thu Jun 16, 2022 4:46 am
- Larsongs
That changes everything.. That should add some good dimension.. Glad it works for you!
Same reason I use a Fender Amp & a Vox Amp… 2 totally different Sounds.. Then split them thru the Keeley 30ms Double Tracker Pedal in different Stereo FX and or with Abbey Mode ADT.. Sounds great!
I haven't played with it a TON, but I agree that it does seem to be much better with other things, like a stereo/dual mono amp setup. I can't remember what mode I used so far, but I had it in a wet-dry setup, and it was glorious.Lost In Autumn wrote: ↑Thu Jun 16, 2022 2:26 pmI was underwhelmed by it on its own, I loathe shimmer reverb and the delay verb was not entirely different from my dispatch master, but I read a suggestion about putting the dials at 11 and 1:00 in the pitch shift mode for a modulated reverb and it’s given the left channel a unique voice that really enhances the stereo spread.Shadoweclipse13 wrote: ↑Thu Jun 16, 2022 4:46 am
- jalexanderdixon
I do it at home for fun sometimes. My GFI Synesthesia has a Leslie effect that sounds insane through two Fender amps.
