What are y'all's dream amps?
Make it loud here.
marqueemoon
Re: What are y'all's dream amps?
Post by marqueemoon » Tue Feb 23, 2021 12:50 pm
marqueemoon wrote:
Mon Oct 26, 2020 4:54 pm
I’m happy with what I have currently, but I guess I’d say a Benson Monarch head and 1x12.
If I’m paying I’m not gonna shell out that kind of dough for an amp, but if we’re dreaming sure.
Ok, I would not turn this down.
https://youtu.be/xlyxbi06wlQ
A+ sound and aesthetics in my book.
geoman
Post by geoman » Tue Feb 23, 2021 6:33 pm
To get my one owner 1968 Vox Viscount back into working condition. Thomas era Vox with 2 x 12 just had an amazing voice. Several voices actually!!
hexes
Post by hexes » Tue Feb 23, 2021 11:38 pm
Dr Tony Balls wrote:
Tue Feb 23, 2021 10:18 am
hexes wrote:
Mon Feb 22, 2021 11:31 pm
ToneFerDayz!!1! wrote:
Fri Dec 18, 2020 4:15 am
Late to the party here, but a tweed Tremolux or a brownface Princeton are pretty much my ideal amps.
Sadly, the originals aren't at all obtainable in terms of pricing.
brown princeton clone was the first amp I built. it's VERY easy to clone, and very easy to make sound absolutely beautiful.
i've brought an original 62 back up to spec for a friend of a friend with some good caps and NOS glass and my clone sounds very good next to it.
I'm not familiar with everyone's skill level here but I wouldnt call anything with a bias modulating tremolo VERY easy to clone. At least not very easy to get it right....those things are tricky (and ticky!).
Related but I recently did a Brownface Deluxe as a head:
I had no problems, but i've only done two bias vary clones and 1 harmonic vibrato clone (plus a tweed deluxe, tweed champ, a pair of reverb units, and currently building a rob robinette mini deluxe.) so I'm kinda new at amp building. what specifically about bias vary tremolo should be challenging?
hexes
Post by hexes » Tue Feb 23, 2021 11:46 pm
Larsongs wrote:
Tue Feb 23, 2021 9:57 am
I’m not disagreeing but I wonder why don’t we see & hear more Browns?
aside from fender reissuing the brown princeton with a 12", they were not made for very long. good quality 4meg reverse audio pots are very hard to find that they used in some circuits (my brown super clone has 3meg for now, with some value changes to slow the trem down) that plus the variances on the circuit designations from say 6g4 (1961-ish) to the 6g4-a around '63 on the fender super.
there aren't many chassis available if you want period correct, and the people who tend to want brownface clones want it to LOOK exactly like original. not my bag, so I'm happy retrofitting.
the surf guitar crowd are huge on the brown era amps. specifically reverb unit, showman, bandmaster, and bassman. there have been some great amp and reverb unit makers doing brown/blonde-esque circuits (nocturne reverb unit. gomez amps...)
originals are rare and expensive, and the blackface amps are much more ubiquitous. the brown/blonde were a middle ground between edgy mid-forward tweed, and the later pop-vocal focused blackface amps.
Larsongs
Post by Larsongs » Wed Feb 24, 2021 7:04 am
Tue Feb 23, 2021 10:19 am
They just didnt make that many of them, I think.
I get that, but, why not?
Dr Tony Balls
Post by Dr Tony Balls » Wed Feb 24, 2021 7:24 am
Bias modulating trems directly effect the amp signal and have a tendency to introduce noises such as ticking, or distortions as the bias voltage of a tube swings away from nominal. In most blackface amps they introduced optocouplers which isolate the tremolo noises and basically just turn the amp's volume up and down, never varying its bias or operation points. Its a bit easier to build easily and well.
Instagram: thetonyballs
Dr Tony Balls
Post by Dr Tony Balls » Wed Feb 24, 2021 7:25 am
I think it's just a transitional thing. They were literally evolving guitar amp technology as they were making these things. Some things were relative blips because they just evolved quickly.
hexes
Post by hexes » Wed Feb 24, 2021 11:43 pm
i've had a LOT of ticking out of a couple hundred opto-trem amps over the past 12 or so years. would love to work on some more bias-vary. the rarity of the brownface amps with bias trem tends to afford me pristine examples when I do run into them.
Maggieo
Post by Maggieo » Thu Feb 25, 2021 9:08 am
A wall of AC30s.
Actually, I'd love to have a proper 60s Marshall Stack, or a Live At Leeds Hiwatt rig.
Yes, my SG is making me play tons of The Who.
Veitchy
Post by Veitchy » Thu Feb 25, 2021 1:40 pm
Are the noises more problematic in higher-voltage amps? I've been lead to believe bias-vary mostly went away because it didn't work in black panel Deluxes and larger. I ask because the bias trem in my Princeton sounds great. Realistically, bias vary is probably my favorite trem type. It has a lovely warmth, and pitch shift and photocell are great, but they can run into becoming a bit of a 'special effect' if you crank them up.
Run a Plexi and a Hiwatt at the same time. I'd love to do that - in my mind it's simply a scaled-up version of Mike Campbell's tweed Deluxe/black panel Princeton rig.
Dr Tony Balls
Post by Dr Tony Balls » Fri Feb 26, 2021 6:43 am
In my experience, yes.
ToneFerDayz!!1!
Post by ToneFerDayz!!1! » Fri Mar 12, 2021 3:15 am
Yeah, I think they were shortlived and not as "iconic" as the other amps that get cloned. There's a bazillion 5E3 clones but very few tweed Harvards, for example.
