They may not be cork sniffer good but they're pretty well regarded by everybody else.OffYourFace wrote: ↑Fri Mar 10, 2023 2:06 pmI might just get an AC15C1 used on CL to tie me over. Most of the demos online sound pretty dang decent.
What are y'all's dream amps?
- hulakatt
Re: What are y'all's dream amps?
She/Her
- Unicorn Warrior
You can’t go wrong really. Hardwired is cool and all, but I probably wouldn’t be able to decipher any difference between them.OffYourFace wrote: ↑Fri Mar 10, 2023 2:06 pmI might just get an AC15C1 used on CL to tie me over. Most of the demos online sound pretty dang decent.
- sal paradise
I had an AC15C1. Sounded lovely with the JM.
Worked fine for gigs, although stage sound was a bit small next to drum kit & bass.
- OffYourFace
That's good to know. I just want it for home playing & recording. I appreciate that the tubes sockets are mounted to the chassis for a cheap amp where others use a PCB with sockets on it. But this is the Dream Amp thread so...sal paradise wrote: ↑Fri Mar 10, 2023 9:23 pmI had an AC15C1. Sounded lovely with the JM.
After doing some research, I almost have the itch to build something but.....ehhhhhh.
- Dr Tony Balls
Get an AC15C1, gut it, and build a proper AC15 using its chassis and iron (or replace the iron if you so choose).OffYourFace wrote: ↑Fri Mar 10, 2023 11:21 pmThat's good to know. I just want it for home playing & recording. I appreciate that the tubes sockets are mounted to the chassis for a cheap amp where others use a PCB with sockets on it. But this is the Dream Amp thread so...sal paradise wrote: ↑Fri Mar 10, 2023 9:23 pmI had an AC15C1. Sounded lovely with the JM.
Instagram: thetonyballs
- repoman
Amps I'd love to own
Selmers, Zodiac, Treble and Bass, Thunderbird, etc
60s Vox AC4, 15, 30, Cambridge, early solid state
Old Valcos, namely 1224 Tremo Tone, Gretsch models especially the country western ones
Magnatone Troubadour 213
Gibson GA6, GA20, GA40, GA88S
H and H IC100
Premier 76 Flip
Supro 1624T
Ampeg Reverberocket, Portaflex b15n, J20
Non master volume early 70s Marhshall JMP
3 Monkeys Orangutan
Orange OR120 with cabs
H and H IC100
Premier 76 Flip
Supro 1624T
3 Monkeys Orangutan
- OffYourFace
I would be lying if I said I hadn’t thought about doing this several times a day haha. I was also thinking of waiting for a used Mojotone NC3015 to pop up and tweak that. I’ve seen a lot of well built Mojotone kits on the used market, mostly tweed amps though.Dr Tony Balls wrote: ↑Sat Mar 11, 2023 4:50 amGet an AC15C1, gut it, and build a proper AC15 using its chassis and iron (or replace the iron if you so choose).OffYourFace wrote: ↑Fri Mar 10, 2023 11:21 pmThat's good to know. I just want it for home playing & recording. I appreciate that the tubes sockets are mounted to the chassis for a cheap amp where others use a PCB with sockets on it. But this is the Dream Amp thread so...sal paradise wrote: ↑Fri Mar 10, 2023 9:23 pmI had an AC15C1. Sounded lovely with the JM.
- wooderson
There's a used Hi-Tone 50 (Hiwatt) available at a decent price and I'm taking a ruler to my knuckles every time I think about going to the shop's website. I'm working to convince myself that I really wouldn't notice the difference in 50W Hiwatt through a Power Station vs. Fractal Hiwatt model through a Power Station to the same cabinet.
edit: phew I looked at the site and it sold
- Dr Tony Balls
Do you want both channels? Or just one or the other?OffYourFace wrote: ↑Sat Mar 11, 2023 11:47 amI would be lying if I said I hadn’t thought about doing this several times a day haha. I was also thinking of waiting for a used Mojotone NC3015 to pop up and tweak that. I’ve seen a lot of well built Mojotone kits on the used market, mostly tweed amps though.Dr Tony Balls wrote: ↑Sat Mar 11, 2023 4:50 amGet an AC15C1, gut it, and build a proper AC15 using its chassis and iron (or replace the iron if you so choose).OffYourFace wrote: ↑Fri Mar 10, 2023 11:21 pm
- Larsongs
I agree get an AC15C1 with a UK Celestion Alnico Blue Spkr.. Swap out the Tubes with some Tung Sols or JJ’s & your done! Great Amps..
Better yet, If you can find a clean used AC15CC1X with a UK Celestion Alnico Blue Speaker.. Swap out with better Tubes & your done..
Both Amps have either 4-5 Tubes! Amazing considering the Great Sounds that these Amps make!!! Not 10 or 12 Tubes, like a Fender or some other Amps, costing several hundred dollars to upgrade…
Good luck…
Good luck…
- echobaseone
And...it's ordered!
- OffYourFace
That's a good question. Having both the normal & TB channels would probably be nice.
I agree. I haven't seen any used C1X models yet. I guess people like them.
- OffYourFace
Wow nice, congrats!
- echobaseone
The USD-GDP exchange made it possible. The only time inflation has ever done me any good. Now I gotta shift this Laney before it gets here!
- hulakatt
The dr504 is still #1 but this has to be a close second for me. Congratulations!
She/Her
