Nice! The Fender demo of the Edge Deluxe sounds amazing. I'm looking at the similiar yet different '57 Custom Deluxe - it sounds tempting.
NAD - Fender '62 Princeton Chris Stapleton Edition
- Surfysonic
Re: NAD - Fender '62 Princeton Chris Stapleton Edition
- Arthon
Bought one last week. I really it's overdriven sound. Never have a amp like that (never had a Tweed, never had a BrownFace). Still tweaking it to find my sound, but it's a simple amp.
The only thing that I would like to change is it's volume. It's loud!!! Louder than a PRRI. I didnt buy it to play with my band. Cannot play it above 2 in my appartment. I would probably try to put a less efficient speaker, or maybe changing the 12" for a 10".
The Blues Cartographer
- Surfysonic
Congrats! I usually play mine around 3 at home (house) and it's not too bad. Do you have the stock Eminence CS speaker? If you swapped it down to a 10" speaker, would you need a 10" baffle as well?
Would an EQ pedal be helpful? I don't often use my Boss Equalizer GE-7 but it's a nice to have when needed.
Brownface amps are my fave.
- Surfysonic
Sorry, double post, please delete!
- Arthon
Yes, I have the stock Eminence speaker. I read somewhere it's a 101db speaker. I could put a Jensen, that is around 92db. I am alsor waiting advice from Weber for their Signature series.Surfysonic wrote: ↑Tue Jul 05, 2022 7:58 amCongrats! I usually play mine around 3 at home (house) and it's not too bad. Do you have the stock Eminence CS speaker? If you swapped it down to a 10" speaker, would you need a 10" baffle as well?
Brownface amps are my fave. I've probably mentioned it somewhere on OSG, but this amp sounds exactly like my (now sold) '64 Fender Princeton (tuxedo).
I have found a Baffle converter if I decide to go 10" : https://www.tubeampdoctor.com/en/baffle ... r-12-to-10
I dont like using a EQ in front of a amp to tame the volume. It feel like turning the guitar volume... A thing I nearly always do when I am playing at home.
- Surfysonic
Sounds good! Good luck!Arthon wrote: ↑Tue Jul 05, 2022 8:03 amYes, I have the stock Eminence speaker. I read somewhere it's a 101db speaker. I could put a Jensen, that is around 92db. I am alsor waiting advice from Weber for their Signature series.Surfysonic wrote: ↑Tue Jul 05, 2022 7:58 amCongrats! I usually play mine around 3 at home (house) and it's not too bad. Do you have the stock Eminence CS speaker? If you swapped it down to a 10" speaker, would you need a 10" baffle as well?
