CME Ice Blue Jazzmaster
tune_link
Post by tune_link » Sat May 18, 2019 8:24 am
I found a pre order page for this Ice Blue Metallic Jazzmaster that is a CME exclusive coming out later this year. Because I’m newer here maybe this discussion has been had before, but what’s up with things like this always having some clincher that ruins them in some way? This one has a blade switch like the Marr Jaguar and no rhythm circuit as far as I can tell. It seems like it could be cool to mod but the lack of that circuit makes me wonder if there’s no cavity up there and it’d require routing like the AmPro Jazzmasters where the lower half of the guitar is just wood since the switch was moved to the upper horn. Always wanted an ice Blue Jazzmaster or Jag, it has the AV65 pickups in it and looks pretty nice otherwise and the price is way lower than I expected (looks to be about $750 USD new).
Is it weird that this irritates me or is that just par for the course with these things?
Unicorn Warrior
Re: CME Ice Blue Jazzmaster
Post by Unicorn Warrior » Sat May 18, 2019 8:28 am
No link?
sirspens
Post by sirspens » Sat May 18, 2019 8:30 am
Public service announcement:
https://reverb.com/item/24012435-fender ... -pre-order
Those look like Classic Player pickups, right? The specs say they are "Pure Vintage 65 Reissue Jazzmaster" pickups.
The tremolo placement is vintage, not Classic Player.
It says it is part of the Player series, but has Jazzmaster pickups. And, once again, the Player Series has the Classic Player tremolo placement, not the vintage placement. It also has a toggle switch, whereas this has a blade switch.
But of a unicorn.
Mechanical Birds
Post by Mechanical Birds » Sat May 18, 2019 9:26 am
Hideous
If I were obsessed with the color I’d go with MJT and for another ~$200/$300 have an actual Jazzmaster
Oliveeer
Post by Oliveeer » Sat May 18, 2019 9:46 am
Well this is what the Player series should've been. No humbuckers and traditional trem placement on a low end mexican model.
Maybe these will be a second alternative to the other Player series JM? Just like the Teles come in both HH and SS configurations.
alexpigment
Post by alexpigment » Sat May 18, 2019 10:02 am
I kinda dig it to be honest. Sure, it's got some things I don't like on it, but it looks like a pretty good modding platform since the routing is all there. And I think the tele 4-way switch could be kinda cool (though that series position could easily sound muddy depending on the pots used). I would probably want to put an American Pro bridge on it as well as those American Performer vintage drop-in tuners, so that's a bit over $100 in mods.
Also, definitely not Pure Vintage 65 pickups in the picture. Either they changed their minds after the picture was taken, or the specs are wrong.
Another use for the route at the top - I do this to almost every Jazzmaster - get two of the same pickups (for example, two pure vintage 65 bridge pickups) and put them in the bridge and neck positions. Then, get a cheap telecaster neck pickup and wire it in after the toggle switch (hot from toggle to ground of pickup wire, hot from pickup wire to the input lug of the volume pot), and put it facing up inside the rhythm circuit cavity. You've then got a hum cancelled Jazzmaster.
tune_link
Post by tune_link » Sat May 18, 2019 10:13 am
Is there a rhythm circuit route under there though? Looks like it might be more wood unless y’all know something I didn’t see or read about this thing.
alexpigment
Post by alexpigment » Sat May 18, 2019 10:58 am
It's listed in the specs.
wooderson
Post by wooderson » Sat May 18, 2019 11:11 am
It's basically a cheaper American Pro JM, I don't really see a problem? The '60s Classic is still available for people who want a sub-$1k guitar with vintage appointments.
alexpigment
Post by alexpigment » Sat May 18, 2019 11:17 am
Not to split hairs, but the price of the Classic went up over a thousand a while back. Not much more, admittedly, but after taxes you're looking at $1100+ USD
BoringPostcards
Post by BoringPostcards » Sat May 18, 2019 12:35 pm
Is that a four way blade switch with an extra option of some sort?
Because that’s the only sensible reason to ditch the standard 3 way toggle. Toggle switches are way easier and quicker to change on the fly.
"Can you please pass me a jug of winter light?" - Lee Ranaldo 2000
Det er mig der holder træerne sammen.
alexpigment
Post by alexpigment » Sat May 18, 2019 2:05 pm
Yes, the specs say it's a 4 way with series and parallel options.
sirspens
Post by sirspens » Sat May 18, 2019 7:37 pm
Alex is the only one reading the specs. haha
Post by 601210 » Sat May 18, 2019 8:45 pm
Hideous
Or swap out the pickguard and the switch and for another ~$60 have an actual jazzmaster.
Or do nothing, and have an actual jazzmaster. Cause it's already an actual jazzmaster. Otherwise the Johnny Marr Jag wouldn't be an actual Jag.
CROSS_guitars
Post by CROSS_guitars » Sat May 18, 2019 9:58 pm
Damn! I'm into it!.
Switch is cool. I probably would angle it but it's fine with me.
