hmm, $154 on ebay + $20 roller bridge + new pots & knobs = awesome
ugh, i need to find a job for the school year
Bigsby B5/ Vibramate V5, meet SG...
- finboy
- skarocker
Re: Bigsby B5/ Vibramate V5, meet SG...
The idea is good but after fitting it I found the flaw. The V5 causes the bridge studs to move a lot due to the string tension on the Bigsby, raising it up from the guitar body and causing terrible tuning problems. I have now removed it and screwed the Bigsby directly onto the guitar...Problem solved!!
- thanasis
Hi I am new here. So I realise that I am very late to this thread.i love sharin foo wrote: ↑Wed Jul 08, 2009 7:30 pmHere's the SG:
and the Bigsby with the Vibramate adapter plate:
The Vibramate adapter is their "SHort-Tail V5 Mounting Kit" that fits SGs with the large guards. In a couple of the photos, you will be able to see where the adapter comes VERY close to touching the guard. The standard model would need to be custom ground to fit.
With the aluminum Gotoh Stop Tail removed:
Vibramate plate installed:
The slug on the teble side must not have been threaded as far as the bass side. On that side the included mounting bolt bottomed out before tightening the Vibramate plate down all the way. Then it DID NOT want to come back out! It took some ingenuity, a pair of Vise Grips, a jacked up screwdriver, and about 37 swear words, but the son of a bitch DID come out. I took it downstairs and sawed the last 3 or so threads off with a hacksaw and smoothed the end (of the bolt) with a file. Afterward it fit perfect. But it was still a pain in the ass.
Okay, Bigsby ON:
Here you can see the thickness of the adapter plate and also how close it comes to the pickguard:
And with a set of GHS .010 to .060 strings, tuned to C standard:
I am considering doing this to my Gibson SG Standard (Bigsby B5 and Vibramate) but I don't want to buy a new case.
Did you find that the standard Gibson case was able to close easily once the B5 and Vibramate were fitted?
- i love sharin foo
Yeah. It fits just like it originally did. You just have to swing the arm back toward the tailpiece and then it fits perfectly.
A death’s head ring upon his finger
- Logan
Oh man! An SG Classic with a Bigsby! You're not helpful for me getting rid of my want for one of those. I love SGs with Bigsbys.
I mean, look at mine! I put a Bigsby on mine months ago with a B3 and the Towner kit. It stays in tune and I got behind the bridge sounds of a Jazzmaster too with it.
I'm in Marching Band and play Guitar. That's about it, pretty boring, isn't it?
- clef051
Great looking bigsby'd sg's!
I put one on my les paul awhile ago with a vibramate, Im so glad I did I love it. I just added a 1 1/8" spring to mine, and the roller saddle to my bridge. I ordered the wrong bridge but the saddles fit in mine so i just switched them . I had graph tech saddles in before but the bigsby use ate through them
