T-Style body with Jazzmaster bridge and tailpiece question
- Fiddy
Re: T-Style body with Jazzmaster bridge and tailpiece question
Not every guitar needs a Jag/Jazz trem. This is one of the ones that don't.
- mgeek
it's never too late to go the smugglers tele route!Fender Addiction wrote: ↑Mon Aug 03, 2020 9:21 pm
What I would change is that I would have routed voids in the body before covering the back in epoxy... anything to remove weight.
- Fender Addiction
Hmmm... had to look that one up... definite possibility to get rid of some weight.mgeek wrote: ↑Tue Aug 04, 2020 6:02 amit's never too late to go the smugglers tele route!Fender Addiction wrote: ↑Mon Aug 03, 2020 9:21 pm
“Dewey Cox has to think about his whole life before he plays.” - Sam McPherson, Drummer for Dewey Cox
- Fender Addiction
I actually do take your word for it, and I appreciate your input. My apologies if my comment seemed to imply that your input was unimportant. On the website, they say 7.25" "and beyond" ... I didn't see the patent applications, as that didn't even cross my mind.andy_tchp wrote: ↑Mon Aug 03, 2020 9:41 pm*Shrug*Fender Addiction wrote: ↑Mon Aug 03, 2020 8:57 pmAt the price I am paying for the Mastery, if it doesn't do what I need, I will definitely be returning it. They have a 30-day unconditional return policy. I'm not big on buying things to "test them out," but there's no other way to know unless I buy one. Otherwise I am only speculating that it will/won't work.andy_tchp wrote: ↑Mon Aug 03, 2020 3:18 amFYI the comments/thoughts on radius and bridge selection don't make sense.
The vintage type bridge you have on there is adjustable to any radius (or flat/'no radius').
The Mastery is not - its [2] saddles are each individually subtly curved (radiused), to allow the design to work with 'all common radius' (meaning 7.25" to about 10" in practice) with the 4 height adjustment fasteners. This is in fact less accommodating of a flatter neck like a 10-16 compound where you want the bridge/saddle radius to be almost flat, which can't be achieved (you can set the saddles as flat as you like, but the curve in each will create a shallow 'm' shape.)
OK, don't take my word for it - It's literally documented there in the product literature and (IIRC) the patent applications.
Last edited by Fender Addiction on Tue Aug 04, 2020 1:50 pm, edited 1 time in total.
- Fender Addiction
I have 2 other Telecasters that are pretty standard. My goal here was to try things out, not build what everyone else has.
- Fender Addiction
Ignore this comment... I was trying to edit my previous comment and instead, I replied... nothing to see here.
- BoringPostcards
I dig it. The vibrato does look a tad awkward on a Tele, but it is better than having the common Bigsby, which is way less stable.
- mgeek
ah - one more suggestion on that (sorry I know you're happy with the way it looks, but I can't help myself )
I see Fender do a tele baseplate that surrounds a Jazzmaster bridge
https://www.instagram.com/p/CDWkowHFhyo/
Not saying this to criticise - I think it looks like an absolutely stunning guitar, but the sawn off plate lets down the finesse a bit imo.
- Fender Addiction
I agree... wish I had seen that before I modified the other one. Although, I could still do it. There are only 2 screws holding the baseplate, and the one in the pic you shared would cover those holes.mgeek wrote: ↑Wed Aug 05, 2020 1:56 amah - one more suggestion on that (sorry I know you're happy with the way it looks, but I can't help myself )
Looks like I may have some other options.
If the bridge I ordered from Mastery works out, I will add this:
https://masterybridge.com/product/mbdc/
If the Mastery does not work out, I may have to rethink the bridge entirely.
- mgeek
Good luck! It looks so cool, deffo worth a further spot of fiddling to absolutely nail it I think.
I'm in the middle of a build with a really heavy bit of wood, and currently trying *ALL* the things to get it down to an acceptable weight. Smuggler routing under the PG + deep belly and forearm carves should get it there
- Fender Addiction
The upside to making your own guitar body is if you want to make changes after the fact, you already know what you are facing by having built it in the first place. And, if you mess it up entirely, you can always build another one..
- Fender Addiction
I revisited this idea today. Putting the thicker end of the shim toward the headstock. This definitely lowered the bridge overall, and looks like it will take care of the issue.
I'm still having to do the dance to a degree, but it does seem to resolve the pinch points.
Moving forward, I am still going to look for more elegant solutions, and would prefer intonation screws that are not inline with the strings. Even if everything else were perfect from the start, I like being able to access the screws without moving the strings out of the way.
There are aftermarket Tele bridge assemblies marketed to work with Bigsby... looks like a possible solution in this case, too.
https://www.schroederguitarhardware.com ... tele-style
- Fender Addiction
Closing the loop on this one... the Mastery bridge came in today. I was a bit concerned that the flat radius of my neck would be a challenge for it, but I managed to get it to match pretty closely to the radius. At least as good as my other guitars.
No more bridge issues... in fact, other than possibly changing the bridge pickup holder to the one I showing here, also from Mastery, and a custom neck plate (currently using a Squire plate with mangled screws), I think I am through working on the guitar.
Future pickup holder:
Final view after setting string height and intonation:
