Not F'N around Vandalism Strat
HNB
Post by HNB » Sun Jan 14, 2018 5:36 pm
Got this from Mr Con-Tiki
A late 80's MIJ V RI body/trem and jack. Really beat, I've had this since the early 90's, it's been my test bed for a ton of pickups. Lots of finish checking and dings and cracks and cred.
A late-80's/ early 90's Fernandes '62 RI neck. I searched for this because it's a match to the one you see in the Paramount show. Veneer rosewood is nearly black, frets are good, profile is fantastic. This neck is dead-flat, and the truss rod works as it should, but the 'plus-sign' nut is split nearly in half. You'll want to find a replacement. That said, I had this strung up for months, and it was a great player. I have a tendency to set everything up with no relief, so a normal set up will be even better. Includes original tuners and neck plate.
To the buyer, i can also offer a 70's pickguard that has been routed for an HB (leaving the original SC mounting holes, just like Kurt's)
He is sending me an old 59 bridge pickup to go with it, so I am on the hook for the rest. Here are his pictures.
Image1 by Christopher Louck, on Flickr
Put together.
Image6 by Christopher Louck, on Flickr
To be honest, I am probably going to aim for that look. I have done the full stickered version, but I kinda don't like the sticker. It feels anti-cop and that isn't me. I think doing most everything aside from the sticker will be pretty cool. Besides, I made my own with a sticker already.
Image20141011_131742 by Christopher Louck, on Flickr
Image20141011_131800 by Christopher Louck, on Flickr
Image20141011_131832 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
HNB
Re: Not F'N around Vandalism Strat
Post by HNB » Mon Jan 15, 2018 12:19 pm
I found a sticker I might use on it online. The funny thing is they didn't give any credit to the source, but I think it might work well if the size is right. I will know better when it comes in.
Christopher
Lilith Guitars
Con-Tiki!
Post by Con-Tiki! » Mon Jan 15, 2018 1:01 pm
(Christopher, also)
HNB
Post by HNB » Mon Jan 15, 2018 1:34 pm
I liked this one, but it is just the letters so it wouldn't look right.
https://www.ebay.com/itm/Better-Dead-th ... nTbNX1kAJg
Christopher
Lilith Guitars
dezb1
Post by dezb1 » Mon Jan 15, 2018 4:37 pm
Coolest strat... ever!
HNB
Post by HNB » Fri Jan 19, 2018 6:08 pm
I got the neck, body, and bucker in the mail today so I went to work putting pots, switch, and pickups in. The sticker I ordered is a bit longer than the Vandalism sticker, but I still really dig it. I put the sticker under the guard where I wanted it and traced the guard so I knew where to cut it so I could have the piece that goes on the guard. It applied pretty neatly. I had a different Fernandes neck and I wanted to swap heel truss rod nuts but it seems that they don't match. I ordered two different heel nuts. Hopefully one of them will work. :) In the mean time here is how it is looking. (Wiring inside isn't done and I decided to do a three way switch since mostly I will be using the humbucker. The neck pickup is a custom made one I had laying around and the middle is a Jaguar neck pickup. I didn't want to fuck around with polarity and stuff, so a three way seemed easiest.)
Image20180119_174942_HDR by Christopher Louck, on Flickr
ImageIMG_20180119_175858_232 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
HNB
Post by HNB » Sat Jan 20, 2018 2:08 pm
Wiring is done! (I know it doesn't look different aside from pickguard screws being in, but the wiring inside is all finished.)
Image2018-01-20_02-00-29 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
HNB
Post by HNB » Thu Jan 25, 2018 4:54 pm
I ordered a vintage Fender heel truss rod nut and it was too small and I got a 5mm import truss rod nut and it is also too small. Is repairing the stock one's cracks a dumb idea? I did some soldering on the cracks after kind of crimping the bent out pieces back in. Seems like that might work or is there something I am missing. It isn't pretty, but here are the cracks soldered.
Image20180125_165027 by Christopher Louck, on Flickr
Image20180125_164953 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
HNB
Post by HNB » Thu Jan 25, 2018 7:56 pm
Neck is on. We will see if the nut holds. It is probably an M6 Metric Nut. Not easy to find.....
Image20180125_174624 by Christopher Louck, on Flickr
Image20180125_174637 by Christopher Louck, on Flickr
An demo.
http://www.youtube.com/watch?v=t8vpVjkU87U
Christopher
Lilith Guitars
HNB
Post by HNB » Fri Jan 26, 2018 9:10 am
It has the soldered up truss rod nut in it currently. Until I can find a m6 nut to replace it, it will have to do. LOL
Christopher
Lilith Guitars
HNB
Post by HNB » Mon Jan 29, 2018 5:27 pm
Found a 6mm nut on eBay just now. Hopefully it will fit. I am sure the other would be fine, I just feel better about having one not cracked in there.
Christopher
Lilith Guitars
Con-Tiki!
Post by Con-Tiki! » Tue Jan 30, 2018 4:22 am
i had that thing strung up for months, and it never gave me trouble.
i did worry about it though, hopefully the new one fits.
(Christopher, also)
HNB
Post by HNB » Thu Feb 22, 2018 6:04 pm
The new truss rod nut came and fit fine... but it was too long... So I took it out in the garage and used my metal cutting bit on my dremel to chop it down. Looks good now. Hopefully it does the job. :)
Image2018-02-22_05-46-20 by Christopher Louck, on Flickr
All together again!
Image20180222_174408 by Christopher Louck, on Flickr
Image20180222_174359 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Con-Tiki!
Post by Con-Tiki! » Fri Feb 23, 2018 2:54 pm
Good stuff.
I'm glad it found a happy home.
(Christopher, also)
