I built this...
- clef051
I built this...
I built a tele I wanted, although its a esquire right now. mjt body, all parts neck, mostly fender hardware. manlius broadcaster pickup. emerson esquire prewired controls. Routed for a jazz master neck pickup I also have another pickguard for when I do that.
Super light I'd be surprised if is 7 pounds, the body is 3lbs 8oz. I still need to get it intonated, but late now and I need to get up early.
Should be quite a fun guitar.
- Hiwatt Bob
Re: I built this...
Nice work!
- clef051
Re: I built this...
Found a problem with using the original tele style saddles. Even with shimming. I ordered the callaham saddles that are for a bigsby, hopefully that should fix it.
- MechaBulletBill
Re: I built this...
Huh. Did you try and file a groove into the brass saddles? It doesn't take much for the strings to cut their own groove but sometimes they need help.
- NICQ
Re: I built this...
Pretty cool build !
Like the blue and the amp knobs
how does it sound? Tele twang + behind the bridge overtones must be quite interesting
Re: I built this...
I was about to say, "put a JM pickup in the neck!" but I see that's already the plan.
Good luck sorting out the bridge issue. That's gonna be one incredible axe when it's done.
- MKR
Re: I built this...
looks awesome. I would also recommed filing a groove in that saddle. I did that when i had a brass smooth saddle for my tele with bigsby. i found i was getting string slippage on a couple strings. filing the groove fixed that.
Eventually i ended up getting some cheap threaded saddles (similar to old school jag JM saddles). they did the trick.
- dezb1
Re: I built this...
Looks cool... just get longer grub screws and they'll stop the strings going off the edge.
