sean's build log (revived)
Re: sean's jaguar build (slow build)
Post by s_mcsleazy » Sun May 07, 2017 1:14 pm
build update.
does anyone have the wiring for a series/parallel/phase switch diagram for the jaguar style switches or a rotary switch?
Shadoweclipse13
Post by Shadoweclipse13 » Sun May 07, 2017 3:30 pm
Series-parallel
Phase
If you want, I could draw you up a whole schematic. Still thinking two Sentell Jag pickups?
Post by s_mcsleazy » Mon May 08, 2017 7:25 am
please. that would be fantastic. i only need one for the bottom plates. i got one for the top plate.
and most likely still sticking with sentells
Shadoweclipse13
Post by Shadoweclipse13 » Mon May 08, 2017 11:58 am
s_mcsleazy wrote:please. that would be fantastic. i only need one for the bottom plates. i got one for the top plate.
So, are you doing the series-parallel, phase switch, and a pickup selector on the bottom plate? Anything else you want on the schematic?
Post by s_mcsleazy » Mon May 08, 2017 2:34 pm
that's enough
Shadoweclipse13
Post by Shadoweclipse13 » Mon May 08, 2017 3:36 pm
Ok cool. Have any preference for which switch goes where? With a Jaguar diamond plate, you've only got room for 3 switches (one for each pickup, and either series-parallel or phase). I'll have to put the other mod switch somewhere else...
Post by s_mcsleazy » Mon May 08, 2017 4:08 pm
Shadoweclipse13 wrote:Ok cool. Have any preference for which switch goes where? With a Jaguar diamond plate, you've only got room for 3 switches (one for each pickup, and either series-parallel or phase). I'll have to put the other mod switch somewhere else...
lower control plate is fine (one with knobs). i have plans for the upper.
Shadoweclipse13
Post by Shadoweclipse13 » Mon May 08, 2017 5:23 pm
So you're not using one of the diamond switch plates?
Post by s_mcsleazy » Mon May 08, 2017 5:24 pm
i am using the diamond plate but if you need to put anything anywhere else that's cool
Shadoweclipse13
Post by Shadoweclipse13 » Mon May 08, 2017 5:29 pm
Got it! I'll work on it tonight, and put it into my usual/easy-to-read style on illustrator tomorrow for you :)
Shadoweclipse13
Post by Shadoweclipse13 » Tue May 09, 2017 4:15 pm
http://s1098.photobucket.com/user/Shado ... rt=3&o=113
So, I realized that I actually already had one made that's pretty much exactly what you want. The only thing it has that you don't is a solo switch (which in my case here, just bypasses the volume and tone pots). Let me know if the link doesn't work and I can try again on a better computer (at home). My work computer sucks.
Post by s_mcsleazy » Tue May 09, 2017 5:26 pm
Shadoweclipse13 wrote:http://s1098.photobucket.com/user/Shado ... rt=3&o=113
hit the nail on the head with that one. i can work that into the diagram i have in my head.
Shadoweclipse13
Post by Shadoweclipse13 » Tue May 09, 2017 5:27 pm
Sweet! Glad it'll work, but SUPER glad that the link worked :D
Shadoweclipse13
Post by Shadoweclipse13 » Thu May 11, 2017 2:09 pm
Home for the weekend, and finally able to get on my home computer. Thought I'd post the link here incase anyone else is interested too.
Shadoweclipse13
Post by Shadoweclipse13 » Tue Oct 31, 2017 3:49 pm
Any progress on your Jag Sean?
