I mounted the neck template I have to the back of the neck, then used a router bit with a ball bearing guide to trace the shape of the template. I routed it to the depth I wanted.onichodaddy wrote: ↑Sun Dec 31, 2017 11:09 pmLooks great so far. As far as shaving off that end piece, did you cut through it with a coping or some other type of saw, use a rasp, use a router or some other method? Would be curious to know so I don’t ruin my neck. Your projects always turn out great so would like to know how you weee able to cut down that heel.
I cleaned it up with a file and sandpaper.
It's probaby best to use a routing table but I did it the risky way by top routing it, which I could have easily screwed the whole thing up.
