Re: Can i do this ?
- block
Can i do this ?
When you have plenty you know that you have enough
- block
- FireAarro
Re: Can i do this ?
Yes. Just rout out the middle bit and jam another pickup in.
Times change. Remember when dog Jimmy used to go white and chalky? Now it grows hair! We got used to it. We'll get used to poly. -blueavenger
- eupat
Re: Can i do this ?
if you keep the JM guard, you'll have the volume hole that stays un-used
- block
Re: Can i do this ?
But all the hardware can fit in that body that is routed like that ?eupat wrote: if you keep the JM guard, you'll have the volume hole that stays un-used
- FireAarro
Re: Can i do this ?
The main problem is the switchplate, which has nowhere to screw into. You could mount some wood blocks in.
- eupat
Re: Can i do this ?
Green Angel put a Jaguar rythm plate on one of his Jazzmaster
he said it was hard to fit, he had to change the bracket if I remember...
try to PM him
for the jack, vol and tone plate I think it will fit.
try to PM him
- the older brother
Re: Can i do this ?
The lower lead pot (tone) seems to go a little tight in that routing - maybe if you use a mini pot It'll go.
- block
Re: Can i do this ?
Im thinking to buy all the jaguar hardware and place them on the jazzmaster pickguard . I will drawn the hardware on the jazzmaster pickguard , then the marked stuff are going to be cut . I think that it will work . The only that problems me is the 3 switch plate . i wil think of something .
- eupat
Re: Can i do this ?
the upper screw of the volume plate and the bottom screw of the scratch will aslo be where there's not wood under
The'Burbz from shortscale.org had to add a piece of wood to be able to screw them:
the whole story >here<
