White witch hat knobs
- Incinerate
Hi guys,
At the moment I'm modding my CIJ with new parts and I'm searching for white witch hat knobs but I can't seem to find them anywhere. Are these even available? I'm also questioning if they will even fit on CIJ pots. Your help is very well apreciated
"Guitars are not taken seriously nowadays. I blame the eighties"
- mynameisjonas
- Admin
Re: White witch hat knobs
check out this thread: index.php?topic=7390.0
- Incinerate
Ok, my bad. I should really use the 'search' function more often
- k o y l
The CIJ pot shaft will be to thin for them... maybe it's time to upgrade your pots to CTS ones...
- eupat
they have a screw, so I think you can put them on every pot, no ?
right now mines should be over the ocean...
- RumorsOFsurF
I put them on my new CIJ just tonight...No probs, just line the set screw up with the split in the shaft and tighten 'er down. You have to hold the knob level while tightening, or it will wind up crooked.k o y l wrote: The CIJ pot shaft will be to thin for them... maybe it's time to upgrade your pots to CTS ones...
Damn kids, get off my lawn!
- berlinbetty
Don't you try NOT to aim for the split? That's what I always did. In fact, I would nudge pots slightly one way or the other so I wouldn't hit the split. I like the 10s to be facing me when I play...
One more guitar, then I'll practice!
- RumorsOFsurF
I like the 10 facing me, as well. However, I was told to put the screw in the split, forcing the halves outward creating tension to hold the knob in place. I guess if it works the other way, that's better. At least the numbers would be in the correct position.
- spaceghost
i'm putting witch hats on my JM today. i don't really care if the numbers line up, but this is all good information. i love this place.
- berlinbetty
That IS an interesting technique. Let me ask you...does attaching the knobs this way allow them to spin in a perfect circle as opposed to an elipse? Probably yet another thing that bugs only me...RumorsOFsurF wrote: I like the 10 facing me, as well. However, I was told to put the screw in the split, forcing the halves outward creating tension to hold the knob in place.
- RumorsOFsurF
Unfortunately, they still move in an ellipse.berlinbetty wrote:That IS an interesting technique. Let me ask you...does attaching the knobs this way allow them to spin in a perfect circle as opposed to an elipse? Probably yet another thing that bugs only me...RumorsOFsurF wrote: I like the 10 facing me, as well. However, I was told to put the screw in the split, forcing the halves outward creating tension to hold the knob in place.
- Hawaii 5-0
With all this talk about witch hat knobs, I'm starting to feel the need to get some myself. I saw a pic of an Ocean Turq. JM with witch hats, and it looked pretty good.
Sent from the Batcave
- k o y l
Like mine ?Hawaii 5-0 wrote: With all this talk about witch hat knobs, I'm starting to feel the need to get some myself. I saw a pic of an Ocean Turq. JM with witch hats, and it looked pretty good.
(hypnotic message: buy some witch hats from Doooouuuuuggg )
- Hawaii 5-0
- k o y l
Thanks
