Original (and not so original) design template thread
roscbarn
Re: Original (and not so original) design template thread
Post by roscbarn » Mon May 19, 2014 12:02 pm
Zemaitis SU501DC outline:
V_____
Post by V_____ » Mon May 19, 2014 2:04 pm
So what programs are you guys using to do these drawings? I've got an idea I'd like to draw up.
www.shoepedals.com
roscbarn
Post by roscbarn » Mon May 19, 2014 3:40 pm
Mainly, Inkscape. Nice enough and free.
Then I mess with the bezier tool for the outline.
Just scale a frontal picture of the guitar using the scale as reference.
07hubbardj
Post by 07hubbardj » Tue Jun 03, 2014 12:30 am
roscbarn wrote:Zemaitis SU501DC outline:
Thank you :D
07hubbardj
Post by 07hubbardj » Tue Jun 03, 2014 1:29 am
Hey, I was just wondering how difficult it is to change the neck scale on a template. I really dig short scales (I have a jag and a les paul) I'm assuming that the bridge would have to be moved closer to the neck? As you can tell ive never built a guitar but I'm trying to learn as much as I can before I start. Any help would be appreciated :)
kdanie
Post by kdanie » Tue Jun 03, 2014 9:41 am
Changing scale is easy, just move the bridge fwd to the correct distance. Depending on the guitar, pickups may need repositioned.
ken
Portuchacho
Post by Portuchacho » Thu Jun 26, 2014 4:31 pm
Hello! This isnt really a custom design or anything, but I need a bit of and tought this would be hte most indicated place. Can someone provide a jazzmaster with tele bridge pickguard template? I Don't mean a telemaster, I really mean a jazzmaster pickguard with a tele bridge cut. I can't find it anywhere and I can't draw it accurately. :fp:
roscbarn
Post by roscbarn » Fri Jun 27, 2014 11:05 am
Do you need just the pickguard cutted to a tele plate, or the whole thing?
You can pick the pickguard (and the whole thing) drawings here (on pdf format):
http://www.gitarrebassbau.de/viewtopic. ... t=6#p18566
If you already have the tele plate you can draw on top of the printed pdf (just make sure of the scale 1:1) and make your custom template.
Portuchacho
Post by Portuchacho » Fri Jun 27, 2014 1:02 pm
I needed the pickuard cut to a tele plate, in a way that both together would cover the bridge pickup hole, yep. Thanks a lot for the website, this is the second time you save me!
potomac
Post by potomac » Sat Feb 04, 2017 9:59 am
I just found this old thread! Thank you Guys, here is my contribution.
But be aware that these drawings are as good as the photos I found on the net. ...not perfect!
Some words about me and my drawings. As a hobbist I have built electric basses and guitars for the last six years. Unfortunately it's difficult for me to do it now, because I'm working for the next years in foreign countries, far from my tools. I begun to search the net for shapes beside the mainstream, looking for forgotten designs but strange and worth enough to remember. Or very simple shapes like the "Thin Twin" or the "Stratotone". Mostly designs from no longer existing companies, or model series run out a long time ago. I use pictures I find in the net and I use Inkscape to reduce the pictures to drawings, that I may use in the future to copy the Instruments. But I allways make changes to the original designs. Not the shapes of the bodies, but electronics, Hardware, size, accessories, shape of the headstock and finishes. I like semi hollow intruments and f-holes. I don't like pickguards as a must, they should have a sense as a design element or they should have a function to cover crazy electronics.They should never cover beautiful wood.
So, all of my drawing are reduced to my personal preferrations.
Kay K161 Thin Twin but with a standard 57mm neck heel.
stay tuned
potomac
Post by potomac » Sat Feb 04, 2017 10:05 am
Harmony H49 Stratotone jupiter with standard 57mm 2.2" neck heel
stay tuned
potomac
Post by potomac » Sat Feb 04, 2017 10:13 am
Harmony Bass H906 (Teisco)
stay tuned
potomac
Post by potomac » Sat Feb 04, 2017 10:19 am
TEISCO Del Rey (Shark Fin) ET-460
....to be continued....
stay tuned
potomac
Post by potomac » Sat Feb 04, 2017 11:50 am
Givson (not Gibson) Challager 4 Bass. Givson was a Company from India. The design is now copied by Warmoth.
stay tuned
potomac
Post by potomac » Sat Feb 04, 2017 11:55 am
GUILD Bass B302-A approx. 1979
stay tuned
