CROSS_guitars
Post by CROSS_guitars » Sun Jun 21, 2020 9:02 pm
Ok, so i routed out the cavity wide enough so that everything lines up centered.
It worked out pretty good.
Fortunately this is a modernised JM body and I don't have to fuss about it being "vintage correct"
hanspanzer
Post by hanspanzer » Mon Jun 22, 2020 2:42 pm
Getting there.
Allparts USA body, 5-6 coats of oil.
Allparts JM neck, Nitro NOS type finish.
Kluson Tuners
Mojo JM pickups
Spitfire tort
Waiting for Staytrem Bridge and hasn`t decided for trem yet.
I have an early 90`s MIj trem that might go on there for now.
mortron
Post by mortron » Mon Jun 22, 2020 6:34 pm
Getting there.
Kluson Tuners
Mojo JM pickups
Spitfire tort
That is a killer build. Very classy and clean.
How do you like the Allparts JM neck?? Curious where you grabbed it... I can't seem to find them as easy as the Strat ones. Definitely not as cheap either.
hanspanzer
Post by hanspanzer » Tue Jun 23, 2020 4:54 am
I bought it from a store on Reverb called "1950s Finishes". The frets where levelled and crowned and a Graphtech nut was installed. Great work on both the finishing and set up.
mortron
Post by mortron » Tue Jun 23, 2020 6:36 am
Sure looks nice. It's a 25.5" scale yes?
ludobag1
Post by ludobag1 » Wed Jun 24, 2020 11:10 am
too hot this days then slow mode
gjn
Post by gjn » Thu Jun 25, 2020 10:37 pm
No clear plan for this one. I managed to successfully cut a 1° neck pocket for this build which is a first. :)
Image2020-06-26_07-34-18 by GN, on Flickr
ludobag1
Post by ludobag1 » Sat Jun 27, 2020 8:13 am
beguin to look like a guitar
need finishing on the neck again
i Don't find what i want but i have find another thing that please me
duck blue
kifla
Post by kifla » Sat Jun 27, 2020 12:02 pm
Looks beautiful!!! What kind of color is that, metallic or glitter powder?
Scout
Post by Scout » Sat Jun 27, 2020 12:18 pm
You French guys have got it going on.
gjn
Post by gjn » Sun Jun 28, 2020 9:29 am
Image2020-06-28_06-25-24 by GN, on Flickr
antisymmetric
Post by antisymmetric » Sun Jun 28, 2020 2:01 pm
^^ 8) Looking good! What's that binding?
gjn
Post by gjn » Sun Jun 28, 2020 11:18 pm
Celluloid tortoise shell. :blush:
It doesn't quite match the guard but i can look out for one that does later.
Edit...
Just realised you were probably asking about the neck on that lovely guitar above mine! :D
Deed_Poll
Post by Deed_Poll » Wed Jul 01, 2020 2:00 pm
On my virtual workbench I've just been playing around with carved top / hollow body ideas. I'm still undecided about the little humps under the toggle switch and tone knob - on the plus side, they balance some of the fussier detailing around the horns / cutaways, but I don't know whether it's starting to look a little too 'premium' and not enough retro cool!
PRS use a similar feature in recessing knobs and switches, but I wondered how it would look to have them proud of the surface like this. The way I make my hollow bodies, I don't think I'd have enough thickness left in that location to mount them if I used a recess like that - the top would only have 3mm or so for them to grab onto. I also wonder whether it is creating a problem with sanding - it's much easier to sand the top and ignore recesses than it is to avoid the little humps!
Anyway, there it is! Let me know your thoughts if you have any :)
Owner Operator of Katz Guitars
Rgand
Post by Rgand » Wed Jul 01, 2020 4:11 pm
Outstanding, DP! What a fine design. Balanced looking. Pleasing to the eye. Good usable layout. What's left? Build one! :?
