Shadoweclipse13
Post by Shadoweclipse13 » Thu May 28, 2020 6:28 am
Scout wrote:
Thu May 28, 2020 6:24 am
Okay, not as good as polarized but not a huge deal. The polarized plug would just insure that the polarity is correct, as the name implies. I’m guessing that it’s a plastic casing?
The sewing machine itself? Yep. Plastic main casing, with a few tiny bits of metal (knobs, etc).
Scout
Post by Scout » Thu May 28, 2020 8:38 am
Without getting too deep into electrical theory, you don’t need to ground the metal chassis,which is what happens when you change a two prong plug to a three prong plug. That third wire, ground, does not carry current except under a fault condition. The chance of a component allowing voltage to go to ground is slight on a plastic bodied sewing machine, it’s much higher with an amp and without that grounding wire you could become the path to ground which could be dangerous.
niksureal
Post by niksureal » Thu May 28, 2020 2:55 pm
got the body cut out. not much of an update but a bit closer.
oof looks like the camera was focused on the carpet not the guitar. more updates soon.
Shadoweclipse13
Post by Shadoweclipse13 » Thu May 28, 2020 11:18 pm
I work industrial maintenance, so I'd be ok with the electrical theory. If the outer case had been metal, I would've changed the plug and not even questioned it. I had my doubts that I'd need a grounded plug, but I definitely wanted to make sure. Thanks for the help dude! Guess I'll just put it back together and use it :w00t:
Scout
Post by Scout » Fri May 29, 2020 4:17 am
Cool, it’s fine as is, I was just explaining why. Sewing, yet another skill set I leave to others, have fun. :D
niksureal
Post by niksureal » Fri May 29, 2020 2:50 pm
routing complete. sand/fill/seal and maybe paint tomorrow.
Rgand
Post by Rgand » Fri May 29, 2020 3:34 pm
Scout
Post by Scout » Fri May 29, 2020 3:52 pm
looks great, I do like those pickups.
tribi9
Post by tribi9 » Sat May 30, 2020 2:33 am
Damn, that looks badass. Great job Nik. 😎
Shadoweclipse13
Post by Shadoweclipse13 » Sat May 30, 2020 2:39 am
I concur! That might be one of, if not the, coolest ones you've ever done. I'm quite excited to hear how those pickups sound.
I was first intrigued by them when I saw the Fender custom shop video where they made a double-neck Jazzmaster for Troy van Leuwen. The 12-string was basically a Telemaster, with a Tele bridge pickup and a 12-string style split coil like that in the neck.
niksureal
Post by niksureal » Sat May 30, 2020 8:50 am
Thanks everyone!
filler/sealer done. have since sanded. hopefully putting colour on this evening.
niksureal
Post by niksureal » Sat May 30, 2020 7:12 pm
paint done. you can really see how imperfect the cavity routing is. i did it all freehand cause i didnt want to make a template. the gold colour i initially wanted was unavailable so i went with a champagne type of gold. im honestly really into it. way more than i expected.
Deed_Poll
Post by Deed_Poll » Sat May 30, 2020 7:41 pm
Looks fantastic, like Shoreline gold. Great work!
Owner Operator of Katz Guitars
Scout
Post by Scout » Sat May 30, 2020 7:44 pm
I don't see a need to make a template for a one off set-up, besides that would just slow you up! The color looks good
Rgand
Post by Rgand » Sat May 30, 2020 9:01 pm
Beautiful job. The color is outstanding.
