Help Identifying a Mystery Neck!
TyPierce
Post by TyPierce » Thu May 02, 2024 3:26 pm
I recently acquired a jazz master project and have build it up. It plays great, sounds great, and while I know that the body and parts are from an American jazz master, the neck is a complete mystery to me.
The facts so far:
- The heel has “1963” written on it and some kind of signature.
- Nice rosewood board, not a curved veneer
- Truss at the heel
- 7.25” radius but frets are a bit bigger/wider than vintage
- Seems to be poly, as the acetone q-tip test turned up negative
- The decal has been removed or sanded off
- The edges of the headstock have also been sanded a bit
- Some of the fretboard edges between frets 5-ish and -9-ish are rolled
- No sticker or serial number anywhere
At first I thought it was an MIM or Squier neck someone relic’d. but something about the way the fretboard is rolled seems real, in that it’s not perfectly even (I.e. some frets are more rolled than others) and the grain is worn in such a way that it doesn’t seem like a straight-up sanding job.
Any thoughts? I’m hoping one of you has come across something like this, or maybe even recognizes the date/sig.
Thanks in advance for any insight!
CROSS_guitars
Re: Help Identifying a Mystery Neck!
Post by CROSS_guitars » Thu May 02, 2024 6:49 pm
looks like Allparts to me.
GilmourD
Post by GilmourD » Fri May 03, 2024 6:50 am
Shouldn't that have the burned-in stamp on the heel, though?
TyPierce
Post by TyPierce » Fri May 03, 2024 7:10 am
Good point. I’m also a bit stymied by the faint “1963” that’s on the heel end by the truss rod, but has faded.
I’m not holding out some crazy hope that it’s a vintage neck, since the markings don’t seem consistent with what little I know about vintage Fender heel markings, but it’s odd to me that at some point in its history it’s been marked with a “1963” on two separate occasions.
GilmourD
Post by GilmourD » Fri May 03, 2024 7:24 am
Yeah, it's certainly not an actual Fender neck let alone a vintage example. By 1963 most necks had a round lam board rather than a slab, anyway, so I'm not sure why 1963 would be on this. Also... It has 22 frets with an extension which didn't happen until the '80s.
CROSS_guitars
Post by CROSS_guitars » Fri May 03, 2024 9:09 am
Some earlier Allparts necks don't have it burnt into the heel.
Steadyriot.
Post by Steadyriot. » Fri May 03, 2024 11:23 am
Nor do their B-stock necks.
GilmourD
Post by GilmourD » Fri May 03, 2024 2:27 pm
Are you trying to tell me that I don't check their site often enough?
[goes to look for B-stock stuff]
TyPierce
Post by TyPierce » Mon May 06, 2024 4:22 am
Sounds like I’m looking at Allparts, which makes sense given the project’s history.
Thanks for the help!
