Looking for some refinishing tips
Snake Hips
Post by Snake Hips » Mon Apr 15, 2024 1:28 pm
Looking to do a black over sunburst project, any tips on doing that with the arm-wear to come through and maybe a few other locations?
copacetic
Re: Looking for some refinishing tips
Post by copacetic » Mon Apr 15, 2024 8:08 pm
Do you have an existing sunburst body youre gonna spray black over? In that case its as "easy" as sanding the finish down a bit (being careful not to sand thru the burst in any areas you want it to show), spraying the black then sanding/rubbing/chipping thru it in spots to reveal the sunburst. This is easier with nitro over poly as the poly underneath wont chip easily but the nitro will.
If youre spraying a burst finish yourself then black on top, i recommend a few coats of clear in between to act as a "buffer" between the two finishes when sanding. Otherwise youre likely to burn thru your sunburst finish not long after sanding thru the black.
Owner/Operator - Feelgood Guitars
