Back when I first started posting here I modified a VMJM by swapping the neck out for an Offset Special neck with a maple fretboard, white button Klusons, black pickup covers, Staytrem Bridge and arm and an MIJ vibrato. This was my main guitar for a few years, but through further acquisitions gradually fell by the wayside until it was just sat on a stand. I never really played it anymore but couldn't really bear to part with it either.
So I put a Paranormal Jazzmaster XII neck on it. It's a pretty basic conversion, apart from the neck all I did was slap the original JM bridge back on it to account for double the strings. It's even still got the vibrato (which actually works quite well and is a lot more stable than I was expecting). I've been having a lot of fun with it the last few days.
The XII neck was actually somehow a little bit narrower than the Offset Special neck at the heel, so there is a little gap in the pocket, but other than that it all went together pretty smoothly and actually sounds really great, I'm excited to write with it.
The Paranormal XII got the original VMJM neck and actually looks pretty sharp. It'll probably want normal saddles at some point, but it's getting a new home with a friend of mine so I'm gonna let that be her problem haha
I kept the Offset Special neck in case I ever wanted to change it back. Really happy with it at the moment but could probably stand to get some new tuners on it, and maybe a black pickguard at some point...
VMJM rides again, XII conversion
- Salfaromeab
Through the tallest wave, into outer space.
- MattK
Re: VMJM rides again, XII conversion
That looks awesome fun. God bless Leo F and his modular designs …
- Nudger
Nice!
A 4 way daka/rotary switch would just top it off n give you that EXII out of phase setting
- BoringPostcards
- CorporateDisguise
How well does the trem work with the extra tension? I’ve debated doing this with an old JM body I have lying around.
Have fun with it!
Have fun with it!
- Salfaromeab
Cheers all, it's a really fun guitar!
One issue is that due to the doubled strings, some of the strings do sit very close to the collet and have potential to rub against it with heavy use, but I'm going to see how it goes
Surprisingly well, the range isn't as much as it was as a six string, and I've not managed to adjust it do the lock works (which admittedly would be handy), but it's pretty stable and sounds cool to use, been doing a lot of Killing Moon hahaCorporateDisguise wrote: ↑Fri Mar 29, 2024 5:26 pmHow well does the trem work with the extra tension? I’ve debated doing this with an old JM body I have lying around.
Have fun with it!
