24" scale neck makers?
- nbc580
I'm putting together a semi-hollow jaguar and hope to have a neck with a Starcaster headstock. Haven't had much luck finding anyone online who does these 24" scale. Does anyone have suggestions?
- AcrylicSuperman
Re: 24" scale neck makers?
Try asking warmoth. They make both 24" scale necks and starcaster necks. It would probably be a custom job though.
- solfege
Musikraft. https://musikraft.com/product-info.php?pid2155.html
Though maybe not with a starcaster headstock, tho. Humm.
- nbc580
Warmoth's response was that none of the 24" tooling or fixtures would allow for any other pegheads.AcrylicSuperman wrote: ↑Tue Aug 27, 2019 10:08 amTry asking warmoth. They make both 24" scale necks and starcaster necks. It would probably be a custom job though.
- nbc580
Emailing them to check. Optimally this would be a 1 piece neck made of rosewood as well.solfege wrote: ↑Tue Aug 27, 2019 11:49 amMusikraft. https://musikraft.com/product-info.php?pid2155.html
- AcrylicSuperman
Dang. That is unfortunate.nbc580 wrote: ↑Tue Aug 27, 2019 12:51 pmWarmoth's response was that none of the 24" tooling or fixtures would allow for any other pegheads.AcrylicSuperman wrote: ↑Tue Aug 27, 2019 10:08 amTry asking warmoth. They make both 24" scale necks and starcaster necks. It would probably be a custom job though.
- JVG
I don’t think Musikraft has the Starcaster headstock programmed in their CNC. They might do a paddle head for you as a special order, if you have the means to complete it yourself.nbc580 wrote: ↑Tue Aug 27, 2019 12:55 pmEmailing them to check. Optimally this would be a 1 piece neck made of rosewood as well.solfege wrote: ↑Tue Aug 27, 2019 11:49 amMusikraft. https://musikraft.com/product-info.php?pid2155.html
J.
- Rgand
You might want to also look for a manufacturer that will make one for you with a paddlehead and shape it yourself. Outside that, you can get the patterns from Faction Guitars and make your own. His specialty pattern set includes Mustang/Jaguar 24" and Starcaster patterns.
- YALCaster
Guitar Builder, in the UK
- nbc580
Confirmed via email that they do not.JVG wrote: ↑Tue Aug 27, 2019 2:19 pmI don’t think Musikraft has the Starcaster headstock programmed in their CNC. They might do a paddle head for you as a special order, if you have the means to complete it yourself.nbc580 wrote: ↑Tue Aug 27, 2019 12:55 pmEmailing them to check. Optimally this would be a 1 piece neck made of rosewood as well.solfege wrote: ↑Tue Aug 27, 2019 11:49 amMusikraft. https://musikraft.com/product-info.php?pid2155.html
J.
Their custom neck page says you cannot use copyrighted headstock shapes.
- YALCaster
I was unaware, my apologies
- JVG
Ok, so none of the “bigger” manufacturers are into it. There are a number of luthiers who
I’m sure would take the job on as a custom build...some of whom frequent OSG.
- nbc580
- kurski
I have used a jaguar 24 neck by Allparts. Flawless qual. but it comes unpainted and you have to smooth the fret ends
