JAG-STANG Prototype - Reverse Engineering
HNB
Re: JAG-STANG Prototype - Reverse Engineering
Post by HNB » Thu Jun 25, 2020 8:16 pm
I have a Fiesta with the 50th Anniversary Sticker on the back of the headstock. Swapped Guards and pickups quite a lot since I got it back in College.
Image20170713_120212 by Christopher Louck, on Flickr
Image20170713_112117 by Christopher Louck, on Flickr
Image20170713_120131 by Christopher Louck, on Flickr
Image20161024_163958 by Christopher Louck, on Flickr
Serial is u031245
[Christopher]
Amon 7.L
Post by Amon 7.L » Fri Jun 26, 2020 5:03 am
Cymbaline87 wrote:
Thu Jun 25, 2020 7:54 pm
Wow, this thread keeps getting more and more incredible.
Thank you. We're doing our best.
Serial is u031245
Thanks for chiming in, Chris.
According to the serial number, your Jag-stang is a MIJ 1995. A very interesting one, also.
What has caught my eyes is that even though the neck is definitely from 1995, pictures of your guitar have just proven my suspect about the mating of necks and bodies from different eras.
Your body shows in fact the characteristic of the revised version, making it a possible one of the very first "transition era":
I still have to identify & decipher the pattern of the stamps in the neck pockets throughout the various years, but I came across one specific sample that might confirm my theory about the mating of different spec'd bodies and necks:
As we can see there's reference of both "95 EX" (ex: demo? Transition era?) and of the later printed "JUL '96".
Again if you guys have the body and or pickguard lying around suitable for a tracing and are willing to help, please chime-in.
It would be of tremendous help. :)
HNB
Post by HNB » Fri Jun 26, 2020 8:38 am
I have the body in my guitar room unloaded. What is the best way to trace it for you?
Edit. I saw your post about how to trace accurately. I can also do a rubbing of my pickguard also for you.
[Christopher]
HNB
Post by HNB » Fri Jun 26, 2020 10:12 am
Fun times. The neck pocket stamp picture I had is from a different body by accident. I had two Fiestas. The body with the anniversary stamp had this pocket stamp. :) I tried to use your link in the other thread, but the cloud file was down. I did a rubbing at the neck pocket and of the pickguard and some more pictures. Let me know if that helps.
ImageIMG_20200626_102545 by Christopher Louck, on Flickr
ImageIMG_20200626_103539 by Christopher Louck, on Flickr
ImageIMG_20200626_102551 by Christopher Louck, on Flickr
[Christopher]
Amon 7.L
Post by Amon 7.L » Fri Jun 26, 2020 11:02 am
Chris! You've been fast :w00t:
I don't know what the problem is with the downloadable pdf in the guide but, anyway I put the file on dropbox and it looks fully working now.
Ready to be used to the new trace be sent via email after being scanned.
Without the template and the scan, perspective will distort pictures too much to make the reconstruction possible with the best accuracy.
For what concerns the accident with the pictures taken off the wrong body, I though about such a thing happening, that's why I've put in the A4 a few lines in which to put description of the item. eg: "pickguard off a 2002 CIJ", "body, Fiesta Red 1996" and so on.
It will make life easier on my part as well when comparing things out.
I do apologies for the hassle, but it's the best way I can think of to accomplish such a task, unless someone has an already available digital trace of a jag-stang body :ph34r:
I've sent you a private message with some details as well.
Trust me, it's a work that's better be done behind the scene as otherwise would incredibly over bloat this already massive thread.
Our readers will appreciate it.
I will nonetheless update the thread when our dirty work is done :)
Double thanks for the patience.
HNB
Post by HNB » Fri Jun 26, 2020 2:37 pm
Emailed you some more rubbings/tracing on your template. :)
[Christopher]
CROSS_guitars
Post by CROSS_guitars » Fri Jun 26, 2020 5:38 pm
I made a template of my 1996 Jagstang.
It's 100% accurate as it was traced using a ball bearing router bit. cavities and all.
Amon 7.L
Post by Amon 7.L » Sat Jun 27, 2020 1:17 am
Thanks Chris!
Now I'll work on it and see where we're at.
Thanks a lot to you as well, Patrick! I'm looking forward to that tracing.
private message sent :)
