ThePearDream's Project Thread
ThePearDream
Re: ThePearDream's Project Thread
Post by ThePearDream » Tue Nov 26, 2019 9:07 am
I have a few projects to update.
1. Last month I had posted to The ARIA 1802t/1803t - EPIPHONE ET 270 DATABASE thread about a Domino Olympic that I purchased. Since then I've done a fair amount of work on it.
From the information available on the web, my best guess on the year of this guitar is 1969. This would mean it predates the Aria/Epiphone versions by a few years.
I popped the neck off to do a refret. Here was the marking on the heel. I have no clue what it says. I took one semester of Japanese in grade 9, skipped half of the classes, and got an F minus minus minus.
Starting to take the frets off:
The wood was pretty dry and fragile, so there were a few minor chips. The worst was by the 15th fret. But even this one was minor. I resurfaced the board and sanded up to 12,000 grit. I found it interesting that the two dots at the 12th fret are smaller than the rest.
Then it got a fresh set of frets with a level, crown, and polish and a few applications of StewMac fretboard oil (which is the only oil I've tried that doesn't turn waxy in a few weeks). I also replaced the plastic nut shimmed with paper and super glue with a proper bone nut and found a replacement for the missing headstock badge.
I disassembled the tuners, gave them a cleaning and lube then reinstalled them. A few weeks of playing with the tuners convinced me that they needed upgrading though. The G tuner was so stiff that I had to use my string winder when tuning.
Since the tuners have a Schaller type F mount screw pattern, I tried looking for Kluson Revolution F-mount tuners without a collar. The only ones I could find anywhere were in gold though. Ultimately, I ended up purchasing a set of the collared models, which required opening up the holes in the headstock. I was reluctant to make a permanent mod to a 50 year old guitar, but in the end functionality trumps everything else. But, the button style is the same, the bushings look almost the same and the screw pattern is the same.
The original tuners were installed a bit wonky, so I plugged the screw holes to get a fresh surface for mounting the new tuners. No pics of the new tuners, but they make a huge difference to the usability.
On to the body.
Here is a comparison between an 80s MIJ strat pickup on the left and the Domino pickups on the right:
The Domino are slightly wider, being in between a strat and tele bridge in the width of the bobbin. The Domino are significantly taller though (around 50%). The poles are clearly smaller as well. I measured the bridge pickup at around 10k. I wasn't able to get a reading from the neck, but it is definitely functional.
This guitar should have had pickup covers originally, which are now missing. So I drew up some new covers and had them 3D printed. The originals would have had holes for the pole pieces I believe, but I chose to do a closed cover.
Here are the custom covers next to a strat cover.
Then I rewired everything. None of the pots or switches were original, so used all new parts. Currently it has just one three-way lever switch for the neck and bridge. The middle pickup is a dead strat pickup that is just there to fill the hole for now. Each pickup has a tone knob and there is a strangle switch.
I am considering a few options for the missing middle pickup.
  1. A custom pickup to match the other two
  2. An off the shelf pickup with a custom printed cover to make it look like the other two
  3. A surface mounted pickup like a gold foil
The last few things I've done are to purchase a reproduction trem arm, put a stainless washer under the jack, and replace the flat head intonation screws. It's worth noting here that the roller bridge has metal rollers rather than the plastic used on some other versions of this shape.
This thing is playing and sounding awesome now. The pickups, despite the high reading, are nice and bright without muddiness, but have a good midrange grittyness. When I put them through my Topanga they really nail that garage-y/surf-y Man or Astroman? sound that I love. This was a steal for $200!
What's next?
I'm going to keep things as they are through the winter. In the spring I'll work on removing the bad maroon finish. I did a test scraping on the rear and I believe the original (laquer!) finish may be able to be saved, provided the person who did the refinish didn't really mess up the edges or corners.
The original finish is a faded fiesta/coral type of color
It would have looked like the Domino Spartan shown below:
If the original finish is too messed up or if I damage it too much while removing the maroon, I'm leaning towards a Daphne blue color as seen on the Olympic below:
Finally, I need to source originals of and/or reproduce the truss rod, neck screw, and jack cavity covers.
2. The Talman refinish is complete and reassembled. I need to get good pics taken, but it looks great.
3. The Mahogany Blaster build hasn't had any progress. I have a neck, but need to wait on good weather to paint the headstock black. I also need a name so I can order or make a decal.
4. I have a new updated take on the shape I've been prototyping. I'm planning to do a quick build of this version in the coming months. I have most of the parts on hand already, and just need to make the body and pickguard. It will be ash with a clear finish and a black acrylic guard.
As previously mentioned, this is inspired by Gibson's experimental late 50s shapes, the St. Vincent signature, Brutalist architecture and my perennial inspiration - Bauhaus design. It has no complex curves, using only simple arcs and a handful of straight lines where necessary. I've been thinking about an offset tele build for awhile, but had trouble settling on an existing shape and decided to come back to this one (it's not easy to tell, but the waist is offset 13°). It's tele-ness should be apparent, but the only tele part is actually uses is the bridge.
loveinathens
Post by loveinathens » Wed Nov 27, 2019 3:46 am
Omg I thought that brutalist Tele thing was a Millimetric at first!
ThePearDream
Post by ThePearDream » Thu Nov 28, 2019 9:39 am
You flatter me sir. I'm a fan of the Millimetric aesthetic, but am nowhere near that level yet.
I took advantage of a Black Friday deal that Ponoko is running to get some templates and parts laser cut. Their new pricing structure is great. You no longer need to purchase an entire sheet of material, just the portion being used. The old pricing wasn't a big deal for mdf or acrylic, but it made metal parts prohibitively priced, requiring you to pay hundreds just for a sheet - plus the cost of laser time. With the new format, I was able to get the control plate cut from stainless for just under $30. In addition, there was a multi-part discount and a 25% off Black Friday discount.
Because the neck I'm using for this project already has a decal, this tele-ish thing is named "Eradicator!"
loveinathens
Post by loveinathens » Sat Nov 30, 2019 4:42 pm
I'm loving the reference! Also, holy shit I didn't know Ponoko stuff was this much more accessible now! Gotta check for plates.
tribi9
Post by tribi9 » Wed Dec 11, 2019 8:08 pm
Your neck says Zhonghua, the symbol for China.
Beware of for sale ads advertising Fender Squires, usually they're neither... and remember.. Say NO to relics!
ThePearDream
Post by ThePearDream » Thu Dec 12, 2019 7:21 am
I appreciate the input. I don't think that is correct though. It does look like the first character in Zhonghua (中华). The second character is missing though. In addition, there is the extra stroke on the bottom right of 中. I'm not sure if the extra stroke should be connected or not (maybe there was poor ink transfer from the stamp), or if it is just the corner of the stamp. The closest characters I can find are:
虫 meaning insect or bug
史 meaning history, or the proper name of "Hiroshi"
or ignoring the extra stroke, 中 by itself, which could mean all sorts of things, middle, average, the surname of "Naka", the proper name of "Ataru".
Of course this would be simpler to figure out if anyone else had every taken pics of the markings on one of these, but I haven't been able to find anything else out there. At the end of the day though, it's past doesn't really matter, only it's present state does.
I was being a bit self deprecating earlier. My knowledge of Japanese is indeed pretty rudimentary. But, in a previous life I was a military cryptologist/linguist/analyst, so these kinds of puzzles aren't totally foreign to me. *rimshot*
tribi9
Post by tribi9 » Thu Dec 12, 2019 2:26 pm
I don't think that's an extra stroke on the bottom, but instead the corner of the stamp too. But who knows and its one of your other guesses? It could be the last name of the guy that put it together.
The character is half of Zhonghua in Chinese, but Kanji uses the same symbols. So if the guitar was made in Japan then yes, it will mean something else.
ThePearDream
Post by ThePearDream » Thu Feb 13, 2020 7:03 am
Holy cow, two months since I've updated this thread. I have been working on a few things though. I recently bought a cheap photo backdrop/lighting setup so I could take some decent pictures of a few guitars I'm selling. While I had it set up this weekend I took some pics of recent projects.
This thing has been done for a month or so now. It's not the prettiest piece of ash, but I wasn't aiming for beauty. It is super comfortable sitting and standing and with a slightly heavier body it balances better now - total weight is around 8 3/4 lbs. I did a quick finish with 4-5 coats of water based poly and a rub down with synthetic steel wool for a satin look to contrast the high gloss acrylic pickguard. I ended up buying new pickups from Bootstrap, rather than reusing some I already had. Neck is a Squeaky Clean P90 (very Jazzmastery), bridge is an Original Recipe (51 style). I'm really happy with the control locations. The tele neck doesn't look right with the body though, so I'm planning to switch that out in the near future.
I also grabbed some better pics of the previous guitar's mate. This also has a Squeaky Clean P90 neck, with a no-name p90 bridge and is tuned to open C.
Also, I hadn't posted any pics of this thing all finished up yet. This is likely the final version of this multi-phased project. The vibrato plate is laser cut from my own design, I believe I posted it earlier in this thread. The vibrato guts are from an import model. The arm was cut down shorter and a new tip was installed.
Better pics of this too:
My rotary switch crapped out pretty quickly, so I replaced it with a simple toggle. I'm not missing the OOP setting, so no big deal.
This shows how goofy the tuner holes were drilled on this Chinese neck.
Lastly, some quick updates on what has become my most played guitar since I built it. I swapped out the Squier VMJM pickups for a set of Bootstrap Lake Surfers. I'm really happy with these pickups for this guitar, they're very versatile. I also changed the value of the resistor and changed the switch to one with a red cap on my experimental rhythm circuit switch (located between the tone knob and jack). Lastly, I upgraded the cheap Chinese locking tuners to Gotohs. I know this thing isn't for purists, but between JM pickups, a lightweight body, a perfect neck, and rock solid tuning, it is such a joy to play. The wear I've put on the fretboard in 2-1/2 years is a testament to that.
The body has been collecting some wear as well, with multiple dings and lots of finish checking:
Actually lastly, I'll just drop this here without (much) comment, 3D print vs original:
Rgand
Post by Rgand » Thu Feb 13, 2020 7:14 am
Well! Good pictures of some fine guitars. :w00t:
