Enlarging the hole in a stainless steel washer?
seattle
Post by seattle » Thu Mar 14, 2019 6:42 pm
How can I enlarge the hole in a stainless steel washer. Currently I'm using a round file but it's slow going at the moment.
BobL
Re: Enlarging the hole in a stainless steel washer?
Post by BobL » Thu Mar 14, 2019 7:02 pm
Stepping bit... hold it in a vise or even C clamp it to a board. One of the best things you can purchase for doing stuff to guitars.
This one is cheap and has done very well for me on a bunch of amp chassis holes, acoustic endpin holes, etc.:
https://www.amazon.com/gp/product/B001C ... UTF8&psc=1
BobL
Post by BobL » Thu Mar 14, 2019 7:04 pm
You could also use a reamer... just make sure it's harder than your washer:
https://www.amazon.com/Woodstock-D4140- ... 005W17DFC/
rumfoord
Post by rumfoord » Thu Mar 14, 2019 7:31 pm
Not the best way at all, but if you have a limited tool cabinet...I bet you could get by using masking tape to strap the washer down to a piece of wood and using a drill. You'd want to use very light downward pressure to keep the drill bit from digging in and catching in the metal.
_nash
Post by _nash » Thu Mar 14, 2019 7:48 pm
I think BobL has it right. There’s a dremel tool that’s a sort of conic grinder. I’ve used it with good results.
Shadoweclipse13
Post by Shadoweclipse13 » Thu Mar 14, 2019 10:41 pm
McMaster Carr
We use these guys for work. Their selection is fantastic, prices are good, and they sell to private citizens (don't need a corporate account). It'll be on your doorstep in 2 days after ordering. (In case the modification doesn't go well)
countertext
Post by countertext » Fri Mar 15, 2019 10:00 am
I don’t have anything useful to add, but I initially read the title of this thread as “Accidentally tearing chunks of flesh out of my thumb and index finger?”.
BobL
Post by BobL » Fri Mar 15, 2019 11:23 am
:D
Yeah... I'd recommend he grab it with a set of vise grips or C clamp it to a board or something...
ThePearDream
Post by ThePearDream » Fri Mar 15, 2019 4:00 pm
McMaster Carr
This is the best advice. Get the right sized washer. If you have an ACE Hardware or similar near you, you can pick from probably a hundred stainless steel washers, and buy a single one for, like, 20¢. That's a much better use of your time (and safer than trying to drill it out).
hpr_hpr
Post by hpr_hpr » Sun Mar 17, 2019 7:44 pm
McMaster Carr
Second that, especially if it's stainless ... those alloys are REALLY hard and finding a step bit that will touch them is going to be expensive (and don't try it with anything but a conical grinder or step bit - I'll guarantee you the hole will be off center ... if it's mild steel a harbor freight bit will work for one or two jobs (don't even try if it's stainless). Finally if you go the modification route make sure you have the washer fixed to something solid and be VERY careful if you're planning on using anything but a pedestral drill ... if the bit grabs very unfortunate events might take place.
seattle
Post by seattle » Mon Mar 18, 2019 7:28 pm
I ended up find some correct washers on Ebay and those just can in (and worked).
Rgand
Post by Rgand » Tue Mar 19, 2019 7:44 am
Having worked with stainless for years, I'm in the 'get the right washer' crowd. Stainless is hard and to drill it out needs pressure so you can get the bit through it before it heats up. Otherwise you'll burn the bit and ruin the washer. The only methods I've seen mentioned here that I've used successfully is a round file or a dremel (or die grinder) and the dremel can grab the thing right out of the jaws on your vice. Vice grips can hold one somewhat but they can also mar the washer so if you're going to see it, that's not necessarily a great option. The round file is really the safest way to enlarge the hole in one that I know of.
