Don't know. I opened up the return request & eBay gave me an invoice of $10.84 to pay for a return label._nash wrote: ↑Tue Mar 12, 2019 7:45 amWhy did you have to pay return shipping? eBay's policy on this is seller pays.Spitshaded wrote: ↑Tue Mar 12, 2019 7:19 amI sent mine back last week & got the refund today. Still had to pay $10 to ship it back, but at least I was able to get a refund on the neck.
Anyone seen these? Xii neck copies
- Spitshaded
Re: Anyone seen these? Xii neck copies
- Cpe4spd
New poster here. I received one of these necks off of Eb*y 3/11. Mine looked really good as far as appearance only. But check out these measurements:
Nut,1 7/8 47.7mm
String spacing cut in nut, 1.80in, 45.7mm
Thickness 1st fret, .91
12fret, .92
Radius I got like 14" quite flat
Neck width 1st fret, .92
5th 2.05
7th 2.09
12th 2.22
Heel width varies from 3 inches up @2.31
end of skunk stripe - - - 2.35
end of heel- -- - -- -- -2.38
still have not determined what I might do with,but guess i might keep
Cpe4spd
Nut,1 7/8 47.7mm
12fret, .92
5th 2.05
7th 2.09
12th 2.22
Cpe4spd
Sit Back, Shut Up and Hold On!
- cmatthes
I'll have to send my neck out to you for a tweaking!ThePearDream wrote: ↑Sun Mar 10, 2019 2:45 pmI did this to mine:
I definitely can't return it now. But, it's a perfect fit for a standard neck pocket.
How does it look in a neck pocket?
- ThePearDream
Okay, I still need to clean up the burn marks from my router...
The only body I have available to pop the neck into is a tele body, so you may see some gap at the end due to the differences in shapes. But, the width is perfect and snug and the fret board overhangs the sides by a mere 3/32" (2.4mm). My Warmoth baritone neck does the same thing, and it doesn't bother me at all.
Doug
@dpcannafax
@dpcannafax
- Rgand
That mod is a good save. You sure won't be pushing a string off the end of any frets on that one.
- Cpe4spd
Yeah.. I think I'll do that to mine and have a real one with 2 3/8 width made later. I got the rosewood one from the dude. The hockey stick end is not quite right either, but good enough for a cheap build
