My Jazzmaster Project.
Nox_Vagari
Post by Nox_Vagari » Wed Jan 02, 2019 2:09 am
Hi,
This is my thread documenting the various modifications and whatever else I decided to do with my Jazzmaster over time.
I bought this guitar a few weeks ago (as mentioned in my into post). It's a 2017 MIJ Fender Jazzmaster 60's.
Here are two terrible pictures of the guitar without any mods or anything done to it:
So the first thing I wanted to do to the guitar was swap out the pickups for something more inline with the original Jazzmaster pickups. Because I had read about MIJ Jazzmaster pickups not being very true to the original design.
After a bit of searching I decided to go for the Curtis Novak JM-V, JM-FAT combo:
Curtis on the left, original on the right:
I also got black pickup covers from Curtis at the same time. Here is the guitar back together:
I'm really pleased with the pickups, the guitar sounds just how I wanted it to.
Okay, guess that's it for now. More to come!
Nox_Vagari
Re: My Jazzmaster Project.
Post by Nox_Vagari » Fri Jan 04, 2019 1:28 am
Oops..
andy
Post by andy » Fri Jan 04, 2019 2:17 pm
Oops..
Hahaha Oh boy. Where’s this going?
Send me western swing vids
Nox_Vagari
Post by Nox_Vagari » Fri Jan 04, 2019 6:56 pm
Down a long slippery path to bankruptcy and alcoholism... That's where.
Nox_Vagari
Post by Nox_Vagari » Fri Jan 04, 2019 9:18 pm
It's not easy removing a poly finish. But after some work here is where I'm at.
Still needs more sanding but at least most of the paint and sealer is gone.
cjs
Post by cjs » Sat Jan 05, 2019 3:10 am
haha! ok how'd you get that poly finish off so quick?
you must tell.
Nox_Vagari
Post by Nox_Vagari » Sat Jan 05, 2019 1:52 pm
you must tell.
Alrighty then. So I used a paint scraper and a heat gun for the body. Just keep the heat gun on the area directly in front of the scraper. It peels off right down to the wood.
For the neck I avoided the heat gun as much as possible because I didn't want to unglue to fretboard or warp the neck. I just used a craft knife with a thick blade and basically scrapped off all the paint. Still not easy but much quicker than sanding for half your life.
cjs
Post by cjs » Sat Jan 05, 2019 3:39 pm
you must tell.
awesome.
super clean work. looks so much cleaner than other photos of the same process. great job.
Nox_Vagari
Post by Nox_Vagari » Sat Jan 12, 2019 2:49 am
So I can't really work on the guitar during weekdays so progress is slow. But today I got to work on it a bit more.
I finished removing the sealer/primer(?) and sanding the body. I went up to 320 grit:
After this I felt like starting the spray work, here is my state of the art setup:
Okay! So what type of finish? And what colour?
The reason I'm refinishing the guitar in the first place is because I wanted to nitro lacquer finish. I'd like the finish to age over time.
As for the colour... Well I thought about Sonic Blue, but I don't know, in the end I actually started to like the black finish more than at first. I also have some ideas for the overall look.
So I'm obviously crazy but I've decided to refinish a black guitar black!
Here's the lacquer I'm using. It's Nitro Cellulose lacquer by a company called PPG.
First very light coat:
Sanded the first coat to get rid of the raised grain:
Second coat:
Well that's all I was able to do before it got too dark.
Nox_Vagari
Post by Nox_Vagari » Sat Jan 12, 2019 9:57 pm
A little more progress.
Here is the third coat after being sanded smooth. Still pretty light coats, as you can see a bit of sand through on the bottom edge:
Here it is after the 4th coat of colour, getting pretty smooth now (apart from orange peal). Oh and I decided to do a matching headstock:
Next weekend I should be able to get to the clear coat for the body.
wproffitt
Post by wproffitt » Sun Jan 13, 2019 7:38 am
Wow! As someone who digs into projects that may seem pointless to others, I can fully appreciate refinishing a black guitar in black just because it’s the right black. ;D I’m impressed with the quality of your work. What is your day job?
TeenageShutdown!
Post by TeenageShutdown! » Sun Jan 13, 2019 9:33 am
So many cosmetic possibilities at this point!
IMO the guitar would look killer with block inlays. If you’re interested, the Jockomo block inlay stickers are of good quality. I have them of a couple guitars & they have held up great. They’re reasonably priced too.
TeenageShutdown!
Post by TeenageShutdown! » Sun Jan 13, 2019 9:43 am
Some food for thought. Although, locating a proper yellow gold pickguard is not so easy.
Nox_Vagari
Post by Nox_Vagari » Sun Jan 13, 2019 8:39 pm
Thanks for the kind words! I'm by no means an expert or anything even close to that. I just have access to a back yard, and a spray gun... and I'm crazy enough to not worry about ruining a brand new guitars finish.
As for my day job... I fix things ; )
Nox_Vagari
Post by Nox_Vagari » Sun Jan 13, 2019 8:44 pm
Oh, I see how you guys operate around here. "Food for thought", really means tempting me away from my money! hah.
Kidding aside, nice guitar! And yes the gold guard is a consideration, but will wait and see how the refinishing goes first.
As for the block inlays I think they could look great too. But at the same time I kinda like the dots also. No decision yet. But again, thanks for the suggestions!
